Author Topic: DOSCab - which DOS  (Read 5376 times)
GadgetGeek
  • Last login:July 09, 2024, 09:32:57 am
  • whatever
DOSCab - which DOS
« on: June 17, 2005, 10:12:44 am »
I'm hoping to get an old machine up and running over the weekend.  What versions of DOS have DOSCab users had the best luck with?  IIRC, I can find discs for DOS 6.22, DOS 7 (aka W98), and FreeDOS.
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
Re: DOSCab - which DOS
« Reply #1 on: June 18, 2005, 03:18:51 pm »
I've had good luck with Dos 7.1 (from the Win98 boot disk).
Chris
  • Moderator
    • Chris's MAME Cabinet
« Reply #2 on: June 18, 2005, 03:22:46 pm »
It should theoretically run on any version of DOS wth an extended memory driver, a sound driver and a VESA driver (or VESA support on the video card).  All my testing has been using Windows 98's DOS.
--Chris
OldSchool79
  • Last login:November 01, 2005, 04:16:57 pm
  • Hello!!
« Reply #3 on: June 21, 2005, 12:13:27 am »
I found the DOS that came with Windows 98 to be the easiest with modern hard disks, long file names, compatibility with old DOS games etc
If you want it stripped of Windows (which is a good thing) you'll need a custom msdos.sys though, I can post this when I get home.
« Last Edit: June 21, 2005, 12:15:01 am by OldSchool79 »
<insert signature here>
