Author Topic: Not another guncon2 thread  (Read 1419 times)
Dexter
  • Patriotism, the last refuge of the scoundrel. -- Irish, darnit!
  • Last login:February 01, 2024, 04:36:19 pm
  • "MAKE POVERTY HISTORY......."
« on: June 17, 2005, 05:36:54 am »
Hi all,
Just took delivery of some wireless guncon2 compatible guns. They were mentioned in a previous thread on the guncon driver.
As you can see from the pics as well as the composite straight through connector and the usb connector, theres a block that plugs into the PS2 which, I take it, houses the 2.4ghz receiver. I have a PS-USB converter to plug that into.
Is it worth installing xp to try get these up and running, or will they not work so don't bother? Also, Is the driver Windows 2k compatible?
Anyone else try set up similar hardware??
Dexter
ZeroPoint
  • Last login:June 19, 2014, 08:07:07 pm
Re: Not another guncon2 thread
« Reply #1 on: June 17, 2005, 06:05:09 am »
If you are going to test this gun the "easy way" do it like this:
1. Connect the big black block to your Playstation2.
« Last Edit: June 17, 2005, 06:19:12 am by ZeroPoint »
Dexter
« Reply #2 on: June 17, 2005, 06:47:21 am »
I'm more concerned about the driver end of things, and unfortunately I don't have a PS two.
I don't fancy reinstalling a different version of windows unless absolutely necessary.
Anybody running the guncon2 drivers successfully on a winndows 2k box??
SirPoonga
  • Puck'em Up
  • Last login:August 18, 2025, 08:28:46 pm
  • The Bears Still Suck!
« Reply #3 on: June 17, 2005, 11:46:31 am »
out of curiousity, where did you get that?  Can two wireless guns work together without intereference...
nobody
  • Last login:September 05, 2005, 02:57:54 pm
« Reply #4 on: June 17, 2005, 01:28:20 pm »
they are on play.com 2 for
