Author Topic: Newbie - Mame in a cab with jamma?  (Read 970 times)
kruger
  • Last login:August 20, 2008, 12:17:20 am
« on: June 16, 2005, 04:22:08 pm »
Hello all
This is my first post here so hello everybody, I am been searching for a while now trying to understand what it is I need to buy in order to add a mamed pc to my jamma cab.
I already have a 28" Hantrax Polo monitor in a standard jamma cab that's wired with 3 buttons with 2 players.
Fat_Trucker
  • Last login:September 08, 2010, 11:44:22 am
Re: Newbie - Mame in a cab with jamma?
« Reply #1 on: June 16, 2005, 05:21:33 pm »
Hi, welcome to the madness  ;D.
Its pretty much all covered if you make use of the search function but generally all you need to convert an existing Jamma cab is a Jpac and an Arcade VGA card from Ultimarc. Plug the Jpac into your jamma harness and connect your AVGA to the Jpac.
TBH if you are going to build a MAME cab from scratch why not restore the existing Jamma cab for PCB's and build a dedicated MAME cab using an IPac?.
I recently converted a Jamma to MAME for more or less the same reason as you but if/when I build a machine from scratch I'm definitely going the dedicated route its less messing about with seperate power supplies and such.
Anyway, best of luck and get us some pics up if you can.
I didn't touch it....honest!
