Author Topic: adding a button  (Read 1755 times)
mvarady
  • Last login:May 09, 2007, 10:28:56 pm
adding a button
« on: June 16, 2005, 01:12:25 pm »
I need to add a button to my cocktail table.I need to cut a hole for it.What parts will i need so i can plug it into the jamma harness??--connectors(type) and wire(18 guage?.please help.
tommy
Re: adding a button
« Reply #1 on: June 16, 2005, 01:31:40 pm »
It depends what game you're trying to add a button to, you might need a kick harness for extra buttons or the jamma harness might have another button wire not in use.
mvarady
Re: adding a button
« Reply #2 on: June 16, 2005, 02:30:18 pm »
There is no extra wire from the harness.I located the slot for button 2 but i don't know what king of connector i need to use.Someone mentioned a Molex connector.Sound right???
SirPoonga
  • Puck'em Up
  • Last login:August 18, 2025, 08:28:46 pm
  • The Bears Still Suck!
Re: adding a button
« Reply #3 on: June 16, 2005, 03:07:29 pm »
First answer what game it is for and why you are adding the button.
mvarady
Re: adding a button
« Reply #4 on: June 16, 2005, 04:58:43 pm »
I have 2 multi game cards and a kung fu master board on the way.
« Last Edit: June 16, 2005, 05:11:15 pm by mvarady »
SirPoonga
  • Puck'em Up
Re: adding a button
« Reply #5 on: June 16, 2005, 05:31:11 pm »
Ok, how many buttons are currently on the cocktail?  Why are you adding this one?  Is it going to be a button that should fall in the realm of jamma?
mvarady
Re: adding a button
« Reply #6 on: June 16, 2005, 05:50:28 pm »
One currently.I bought this cocktail table with all the pac mans,all the donkey kongs,galaga,dig dug,galaxian,and frogger.
My new PCB has 19 games in it.Moon Patrol you have to jump,so i need to add that second button.When i get my Kung Fu Master board i'll need to kick.It is a Jamma harness.
tommy
Re: adding a button
« Reply #7 on: June 16, 2005, 06:08:09 pm »
If you only have one button hooked up you should have two more on the jamma harness you could use.
mvarady
Re: adding a button
« Reply #8 on: June 16, 2005, 06:20:00 pm »
I know that.All i need to know is what kind of wire and connectors do in need.Thats all.and where to get them.
SirPoonga
  • Puck'em Up
Re: adding a button
« Reply #9 on: June 16, 2005, 06:22:42 pm »
you need to hook up through jamma harness.
See a jamma pinout.
http://www.coin.demon.co.uk/jamma.htm
tommy
Re: adding a button
« Reply #10 on: June 16, 2005, 06:25:28 pm »
Take the wire that says button 2
« Last Edit: June 16, 2005, 06:33:26 pm by tommy »
mvarady
Re: adding a button
« Reply #11 on: June 16, 2005, 06:47:47 pm »
The problem is i have to do the wireing.I need to know what kind of connector i need to connect to the wire to plug into the jamma harness.Follow me???
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
Re: adding a button
« Reply #12 on: June 16, 2005, 10:59:55 pm »
I'm not trying to be a smartass, but since you are asking a fairly basic question about wiring, do you know that you have a *Jamma* harness installed (if you do, then great).
The main reason I ask is that a Jamma harness is typically pre-wired with at least three buttons per player, so you would just need to take the wire from the appropriate pin on the Jamma harness and connect it to the button in question. There would be no need to connect anything to the Jamma harness itself.
What kind of cocktail cabinet do you have and what boards (preferably more specific than multi-game) are currently running in it ?
A good picture of the harness itself would help a ton in clearing things up.
Cheers.
EDIT: I wrote this much earlier in the thread and didn't hit submit at the time, I guess. After reading the entire thread, it sounds like perhaps your "Jamma harness" is missing the wires in question. In that case, we would need to know how the wires are connected to the  connector (e.g. could be soldered, could be molex-style, etc.). A picture would likely get a quick response.
« Last Edit: June 16, 2005, 11:04:29 pm by CheffoJeffo »
Working: Not Enough
Projects: Too Many
Progress: None
