Author Topic: Mame wah Lists  (Read 1630 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
Mame wah Lists
« on: June 12, 2005, 04:20:19 pm »
Hi im using mamewah at present and am wondering how do i or is there even a way of sorting out the games by the types they are ie sports, fighting, beat em ups, shooters etc?
And if so can there be mulitiple set ups so its easy to select favourites etc.
If there is could some one tell me what i need to do please as searching through 5000 games can get ya down lol :(
Many thanks people - Marky
jcrouse
    • CPViewer
Re: Mame wah Lists
« Reply #1 on: June 12, 2005, 05:44:06 pm »
Currently, for consoles, there isn't an answer. For mame you can use the catver.ini file.
John
Marky_1979
    • Personal Webspace
Re: Mame wah Lists
« Reply #2 on: June 12, 2005, 06:00:32 pm »
yes what is this catver file and what do i do with it?
jcrouse
    • CPViewer
Re: Mame wah Lists
« Reply #3 on: June 12, 2005, 06:20:00 pm »
http://www.mameworld.net/catlist/
Download the "standard" file and place it in your mame folder. In MameWAH's ini file that you use to launch Mame put the path in like so:
### List Generation Settings ###
rom_path                                  c:\mame\roms
rom_extension                             zip
dat_file                                  c:\mame\mame.dat
nms_file
catver_ini_file                           c:\mame\catver.ini
list_generation_method                    rom_folder_vs_dat_file
Now you should be able to generate filtered lists using the menus within MameWAH. You'll have to figure that out. If I told you everything, what fun would that be. :)
John
Marky_1979
    • Personal Webspace
Re: Mame wah Lists
« Reply #4 on: June 13, 2005, 05:30:36 am »
For some reason this doesn't seem to work for me :(
Marky_1979
    • Personal Webspace
Re: Mame wah Lists
« Reply #5 on: June 13, 2005, 06:58:53 am »
where do i get the dat file from too as i dont seem to have this
jcrouse
    • CPViewer
Re: Mame wah Lists
« Reply #6 on: June 13, 2005, 08:11:28 am »
You create it yourself. Go to a command prompt, switch to the mame folder and type this:
mame -listxml|xml2info > c:\mame\mame.dat
If may take a little while depending on your system. Also you may need to change the redirect path.
John
Marky_1979
    • Personal Webspace
Re: Mame wah Lists
« Reply #7 on: June 13, 2005, 10:09:33 am »
Thanks John will try this :) what is the purpose of this dat file? can i not run it without it?
Brewser
  • Last login:August 10, 2006, 02:01:48 pm
  • Fighting the forces of evil since 1978
Re: Mame wah Lists
« Reply #8 on: June 13, 2005, 05:01:56 pm »
I have been using Mamewah for a couple weeks and I have never used the dat file. I am also curious to what this does. So obviously you don't need it, but what the heck is it for?
Brewser
Re: Mame wah Lists
« Reply #9 on: June 13, 2005, 05:03:10 pm »
Another thing I can't figure out is the filters for controls, they don't seem to work properly. I put in the filter for trackball and it lists trackball and joystick games. Am I missing a file here?
