Author Topic: Question for UK members about coin doors  (Read 2066 times)
eggedd2k
  • Last login:February 14, 2006, 09:38:56 am
« on: June 10, 2005, 06:57:45 am »
i've asked about this before but there was much confusion over how a coin door works - US and UK coin doors and mechs apparently work very differently.
so, a question for UK cab builders/owners:
I am currently in the planning stage of building my own mame cab. i want a fully operational dual (two slot) coin door which will register a credit via a microswitch for ANY coin that is inserted. by ANY coin I mean 5p or 10p or 20p or 50p or
Franco
Re: Question for UK members about coin doors
« Reply #1 on: June 10, 2005, 07:51:36 am »
I may be wrong but your best bet will probably to get a dual insert (two player) coin door fram happs and then modify the 25c coin mechs that come with it to accept any coin.
There is a turorial on how to do it here:
http://www.arcadecontrols.org/yabbse/index.php?board=2;action=display;threadid=19200
Edit:
Your other option (are there any more?) would be to get a coin door and mount electronic coin mechs. This would give you the option to insert 10p, 20p 50p and
« Last Edit: June 10, 2005, 07:56:58 am by Franco »
Stu_C
  • Last login:April 20, 2018, 03:54:39 am
  • Reading, UK
« Reply #2 on: June 10, 2005, 08:25:51 am »
eggedd2k,
Where are you buying your coin door from? Seems to be very pricey to have one shipped to the uk. Wondered if you have another source?
markb
  • Last login:April 30, 2011, 06:41:02 am
  • The One and Only.
« Reply #3 on: June 10, 2005, 08:50:19 am »
I recently bought a two slot one from the company that is currently holding this auction on ebay.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=575&item=6185261263&rd=1
It cost me
eggedd2k
« Reply #4 on: June 10, 2005, 09:00:38 am »
none of the arcades i've rang have any coin doors and there arent any decent looking ones on e-bay at the moment.
i've found a site which has a tutorial on how to make a coin mechanism with a micro-switch.  All I really need to get hold of is the coin door itself and i can do the rest.
any ideas where i might get a cheap coin door on it's own?
markb
  • The One and Only.
« Reply #5 on: June 10, 2005, 09:15:13 am »
Could you post a link to the tutorial on how to make the coin mechanism?
eggedd2k
« Reply #6 on: June 10, 2005, 09:26:58 am »
http://www.underthepier.com/01_howtocoinmech.htm
it's pretty basic but i can see it would work if i had a coin door
markb
  • The One and Only.
« Reply #7 on: June 10, 2005, 10:21:38 am »
Excellent little tutorial, I have a double coin door that is missing a mech so i will give that a shot.
Eggedd, what sort of door are you after? can you post a picture of the type you would like.
eggedd2k
« Reply #8 on: June 10, 2005, 11:10:44 am »
yeah i was dead pleased when i came across that tutorial - i'll post it in the main forum as it's own thread.
i've managed to get a coin door locally. cost me
eggedd2k
« Reply #9 on: June 10, 2005, 11:15:23 am »
by the way the door i just picked up looks the same as this one:
markb
  • The One and Only.
« Reply #10 on: June 10, 2005, 11:52:25 am »
Shouldn't be more than
