Author Topic: Happ Trackball Mounting Question  (Read 1400 times)
nickbuol
  • Last login:July 22, 2025, 09:55:45 pm
  • 2nd Time Around
« on: June 09, 2005, 11:56:21 pm »
I am having a cabinet maker price up the cost to laminate and cut (with a CNC machine) my cabinet, and just found out that he can have the machine to button holes and so forth too.
Anyway, I will be getting my first real trackball next week (3" Happs #56-0300-11) with the corresponding mounting plate (#55-1101-00)...  Anyway, I wanted to make sure that I was doing this right.
So I have them cut out a square that is 5.6" by 5.6" and then the mounting plate (6" x 6" just covers it all, or do I only cut out enough for the ball itself, and then use my router to reduce the thickness of the area to get the ball at the right height?
The mounting plate instructions are at (http://www.happcontrols.com/trackballs/55110100m.htm)
The trackball install sheet (that doesn't show any mounting help) is at: (http://www.happcontrols.com/images/pdf/ins-0053.pdf)
I've got my 1 1/8" holes for the buttons and joysticks all mapped out already.
darktemp
  • Last login:July 20, 2006, 11:18:39 pm
  • Rumbler
Re: Happ Trackball Mounting Question
« Reply #1 on: June 10, 2005, 12:14:16 am »
You should have them route out X" x Y" (the size of your mounting plate) to the depth of the mounting plate if you want to flush mount it with artwork or plexi on top.  Then you can either cutout the full square as shown on happs site for the trackball or better yet just cut out an area big enough for the trackball housing.
« Last Edit: June 10, 2005, 12:17:34 am by darktemp »
nickbuol
  • 2nd Time Around
« Reply #2 on: June 10, 2005, 12:31:16 am »
If I end up putting plexiglass over top of the control panel, will that make the trackball not be the proper height?  It would need to be some pretty thin plexiglass I would think.  Right?
