Author Topic: ArcadeVga Help  (Read 1517 times)
Crimsons
  • Last login:January 02, 2024, 07:10:29 am
ArcadeVga Help
« on: June 09, 2005, 05:01:18 am »
Hi I am VERY new to this so please bare with me in regards to my ignorance in this area. I recently purchased an "old" jamma arcade cabinet, in which I was hoping to convert to a Mame cabinet. I consequently purchase a J-Pac and ArcadeVga from Ultimarc. Everything "appeared" to be relatively straight forward. I consequently connected the ArcadeVga and J-Pac to my PC, and arcade machine.
After connecting these "plug and play" cards, I turned on the PC and arcade machine to have a test run. I was able to identify my usual boot sequence appearing on the arcade monitor. However there is severe "flicking" taking place. Consequently I can not make out any writing being displayed on the screen, and this continues when Windows98 loads up.
I also tried to remove the 31KHz jumper from the J-Pac and had no success with that.  I also don't seem to notice the SYNC IN or SYNC OK lights ever being on.
I can't see anything on the screen at the moment, to even identify if i have the correct video driver assigned. Anyone know what may be wrong ? or have any ideas of how i can correct this.
I'm sorry if i have posted this on the incorrect location etc.
Thanks very much.
divemaster127
  • Trade Count: (+60)
  • Last login:December 02, 2018, 08:05:08 pm
  • My webstore is arcadeemulator.net
    • arcadeemulator.net
Re: ArcadeVga Help
« Reply #1 on: June 09, 2005, 03:04:47 pm »
hello, i have the same setup, you have to download a patch for the arcade monitor for utimart.com, it will fix your problem, its a patch spec. for the arcade monitors
thanks
divemaster127
I carry both ultimarc & happ items, all brand new & I ship from the united states. My online store is ARCADEEMULATOR.NET, pm if I can help in anyway.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: ArcadeVga Help
« Reply #2 on: June 09, 2005, 04:27:14 pm »
I am not sure what Divemaster is talking about here...
The most common reason for your problem is that the J-PAC has no power, ie the cable to the PS keyboard or USB port is not connected.
Andy W
Crimsons
Re: ArcadeVga Help
« Reply #3 on: June 10, 2005, 10:08:46 pm »
Thank you very much Andy.  That was the problem.
