Author Topic: Cheap and Easy Driving Wheel/Pedals  (Read 2164 times)
Knievel
    • Knievel Kustoms
« on: June 07, 2005, 10:06:09 pm »
I'm posting this for those looking for a cheap way to add some fun to their driving games.
I purchased a basic Microsoft Sidewinder wheel/pedal combo on eBay and it works great with a number of them. Games like Pole Position 1+2, Turbo, Hang-On, Outrun, Chase HQ, etc. It won't work for games like Super Sprint where you have to spin the wheel all the way around.
There are paddle-switches behind the wheel for switching gears and 6 buttons on the front for extra things like Nitrous. A nice feature is the quick clamp underneath so you can take it on and off in one move. It's also got 3 thick rubber pads underneath it so your CP won't get messed up.
It has just a single USB connection so you can connect and disconnect it anytime,
« Last Edit: June 09, 2005, 08:37:21 am by Knievel »
Chris
    • Chris's MAME Cabinet
Re: Cheap and Easy Driving Wheel/Pedals
« Reply #1 on: June 07, 2005, 10:21:55 pm »
Pole Position 1/2 are 360o wheel games.
--Chris
Knievel
    • Knievel Kustoms
« Reply #2 on: June 07, 2005, 11:56:55 pm »
I played them both last night, seemed fine. Actually a few of the 360
« Last Edit: June 08, 2005, 05:21:37 pm by Knievel »
ahofle
    • Arcade Ambience Project
« Reply #3 on: June 08, 2005, 12:19:11 pm »
I actually was just looking at this the other day (I also have that sidewinder wheel).  Unfortunately, the lip on the front of my control panel isn't big enough. :(  Glad to know it works with the games though.
Chris
« Reply #4 on: June 08, 2005, 03:54:03 pm »
My Logitech wheel fits, but I had to build a spacer to protect the trackball when it's mounted.
I usually use the Player 2 joy as a shifter rather than the padle buttons.
--Chris
--Chris
Knievel
    • Knievel Kustoms
« Reply #5 on: June 08, 2005, 04:30:40 pm »
That's a good idea Chris. Just tried it and mine's a little far back but it does the job.
The lip on my CP was a little shallow too so I modifed the clamp.
Basically I cut the bracket part to the depth I needed and then drilled a hole further back on it to re-insert the screw assembly...
ahofle
« Reply #6 on: June 09, 2005, 01:03:51 pm »
Hmmm, I may have to try that, thanks!
And I love the idea of the joystick shifter.
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
« Reply #7 on: June 09, 2005, 03:33:45 pm »
Does it work with Spy Hunter?
markb
  • Last login:April 30, 2011, 06:41:02 am
  • The One and Only.
« Reply #8 on: June 09, 2005, 04:02:02 pm »
Kudos to who ever came up the idea of using a joystick as a shifter ;)
I'll be trying that with my cab as I use a Saitek R80 which is very similar to the sidewinder.
