Author Topic: metal between wooden control panel, help!  (Read 1084 times)
skybluestav
  • Last login:August 30, 2005, 11:06:10 pm
    • Cypriot Gaming Network
« on: June 07, 2005, 07:47:27 pm »
Hey guyz,
today i was in the stage where I took the control panel off my arcade cab in order to drill new holes to make the cab from a 3 button to a 6 button. But to my amaizment found that the 2 joysticks are held by a steel plate :o
today Ive been round all the hardware stores trying to find a 1 1/8" drill cup to make the holes (which btw is 28-29mm in the UK) and havent found any, the closest I have come to that is 25mm and 32mm. Anyone that can help? know where I can find a 1/18" or a 28-29mm?
And also what is the easiest way to get through a metal piece also?  ???
this has now staled my whole opperation and dont know what to do! I thought I had a problem in that I havent found the right size to drill a hole but now I also need to go through a steel plate.
What is the best solution now? what are my options? urgent help needed!
IM STUCK!
"We do not stop playing games because we grow old, we grow old because we stop playing games!"
skybluestav
Re: metal between wooden control panel, help!
« Reply #1 on: June 07, 2005, 08:15:25 pm »
ive sat down and thought about it for a bit, and it seems Im gonna have to build a new control panel from scratch, anyone know where I can order a 1 1/8" hole for my drill? any websites that ship to the UK? :-\
flyguy1821
  • Last login:October 23, 2022, 11:06:19 pm
« Reply #2 on: June 07, 2005, 09:03:32 pm »
Type in "hole bit" on ebay and you will find tons of sellers.
skybluestav
« Reply #3 on: June 07, 2005, 11:09:35 pm »
found these guyz on the net. UK company
www.tooled-up.com
made my order, so hopefuly I will be able to saw through the metal
AlanS17
    • AlanS17
« Reply #4 on: June 08, 2005, 01:18:14 am »
I can't visualize your dillemna. Could you take a picture? I guess it doesn't matter if you're just starting over.
Kev-in DFW
  • Last login:September 10, 2008, 12:36:09 pm
  • Duke it out amongst yourselves...
« Reply #5 on: June 08, 2005, 02:53:44 am »
A "hole saw" will take care of your problem.  That should cut through almost anything.  It will easily cut through wood, metal, and plexiglass.  The set I have is a Milwaukee and I haven't found anything it can't cut through.
Good luck and let us know how it turns out!
Kev~
The biggest tragedy in life is not death, but what dies inside of us while we are still alive...
skybluestav
« Reply #6 on: June 08, 2005, 06:32:13 am »
they give me a year warranty with this little thing so hopefuly it will do the job!
used this: http://www.tooled-up.com/Product.asp?PID=10877 with this http://www.tooled-up.com/Product.asp?PID=10921
Kev-in DFW
« Reply #7 on: June 08, 2005, 07:53:36 am »
EXACTLY!  and Starret makes some good tools!  Good find, perfect solution!
Kev~
skybluestav
« Reply #8 on: June 09, 2005, 09:06:12 am »
OMG guyz!
http://www.tooled-up.com cant praise them enough! made my order in the early hours of wednesday items arrived early monring Thursday!  :o :D ;D
unbelievable. and the hole saw cuts through anything and exactly the size I wanted!
thanks http://www.tooled-up.com
must shop site for anyone using tools in the UK
AlanS17
    • AlanS17
« Reply #9 on: June 09, 2005, 10:30:11 am »
Just like a saw blade, those hole saws will start to dull. Be sure to sharpen it periodically - especially if you're going through tough material.
