Author Topic: How to scan ?  (Read 1683 times)
SWCP
  • Last login:June 08, 2005, 01:02:11 pm
How to scan ?
« on: June 06, 2005, 12:07:42 pm »
I was just wondering how do you scan CP art with out removing the overlay from the game ? ???
Baker535
  • Last login:January 24, 2009, 11:16:40 am
  • Haha, Full member baby!
Re: How to scan ?
« Reply #1 on: June 06, 2005, 03:23:14 pm »
Are you sure you can't just remove the CP and place it on a flatbed scanner?  It should only be a few pieces to put together digitally... It doesn't matter if the lid closes. Any exposed part of the scanner bed would just appear as black.
If not...
The only thing that comes to mind is to use a digital camera and a tripod or rig a suspension system for the camera to hover above the CP. Take very high resolution shots and piece it together with photo editing software like Photoshop...
I know there use to be pen style scanners but I have no clue how good they work. Also piecing together possibly hundreds of highlighter sized scans doesn't sound like a fun evening  er, month... even if it came with software to help do it.
Maybe someone else is aware of some type of equipment... but that's my stab at an answer. Good luck!
-baker
PoDunkMoFo
  • Last login:January 09, 2025, 07:20:35 pm
  • If we weren't all crazy we would go insane... JB
    • Visual Horizons
Re: How to scan ?
« Reply #2 on: June 06, 2005, 08:41:55 pm »
If the flip up lid on your scanner comes off you could just set the scanner upside down on the control panel.*
*PoDunkMoFo makes no guarantees as to the safety of the above mentioned method.  Should injury or death occur  PoDunkMoFo shall be held blameless.
SWCP
Re: How to scan ?
« Reply #3 on: June 08, 2005, 12:50:54 pm »
It's a Centipede cab I don't think I can remove the CP but even if I did the art work wraps around the front.
I'll try to remove the scanner lid and see how that works thanks.  I'll let you know how it works.
