Author Topic: xbox/gc/ps2---->PC monitor  (Read 1145 times)
neo-geNo
  • Last login:June 13, 2005, 05:04:29 pm
« on: June 05, 2005, 10:30:47 pm »
From what I got from the game consoles section of this site, I can just hook up my systems to my pc monitor using component cables (so that instead of doing the same with a tv, its now with a monitor).  Will this actually work?  It seems to easy  ;)
AmericanDemon
  • Last login:September 22, 2019, 11:08:03 pm
  • Still an AmericanDemon
Re: xbox/gc/ps2---->PC monitor
« Reply #1 on: June 06, 2005, 12:45:46 am »
Well its not quite that easy.
As the Computer Monitor doesnt have a port for Component cables to connect.  As such, you need a device called a transcoder to do it.  Personally though I would go the route of X2RGB.  Its 200 bucks, but its the best device for the job.
neo-geNo
« Reply #2 on: June 06, 2005, 02:04:42 am »
Thanks for the help  :)
PacMon
  • Last login:November 18, 2022, 12:26:24 pm
  • Too many projects for 2 hands!
« Reply #3 on: June 06, 2005, 08:38:12 am »
The VD-Z3 would be able to connect all 3 consoles to a pc monitor.  I was looking at purchasing it a while ago and read that the quality is very good.  Not sure on the differences with the X2RGB, but it's only $60.  Depends on your budget....
http://www.vdigi.com/
neo-geNo
« Reply #4 on: June 06, 2005, 04:21:06 pm »
hmm, it seems that the VD-Z3 only supports proggressive scan games  :-\, so if I'm playing a game that doesn't support it, I'll get nothing on my screen.  For those that have it, is this true?  Also, I would love to get the xrgb-2+, but its sort of out of my budget  :(  I was looking into getting this for my ps2 and gc (x2vga for my xbox): http://www.lik-sang.com/info.php?category=219&products_id=3235&
My question is though, is the d-terminal connection for my gc/ps2 150$$ better than the tv s-video quality (what the product in the link will display it seems, not the best, but better than average)?
SOAPboy
  • Last login:August 01, 2009, 03:36:12 am
  • ..::GeeK::..
« Reply #5 on: June 06, 2005, 04:22:48 pm »
Search VGA BOX on ebay and google..
Theres DOZENS of multi boxes that work great..
neo-geNo
« Reply #6 on: June 06, 2005, 06:02:02 pm »
hmm, from jeremy's article (http://www.tiptonium.com/videogames/reviews/ps2/xrgb2plusps2.htm)  It seems that monstor s-video cables equal (maybe even better) the same quality as a rgb/d terminal cable.
"Nonetheless, the Japanese RGB cable will give you the best image quality available. There are a few problems however. First of all, I cannot in good conscience say that it is significantly better than that available from a Monster Cable Gamelink 300 (S-Video). The improvement is marginal at best. Indeed, comparing the output from a GameCube with a cheapo S-Video cable and a PlayStation 2 with a Japanese RGB cable, both consoles running XGIII: Extreme G Racing, I could see no difference between the two. Looking very closely at on-screen text, there was a marginal, and I mean marginal improvement of the RGB over the S-Video."
If true, I might be better off going with the 50$ s-video vga adaptor and using monster cables (note: I'm not looking for the best video output, but an above average solution, once the next gen systems hit the market, I can just get a progressive scan vga adaptor (VD-Z3) and not have to worry about 480i games not being displayed (problem with the ps2))).
