Author Topic: Source for CLEAR levers behind the reject button on coin door?  (Read 1996 times)
tivogre
  • Last login:July 18, 2013, 09:13:34 pm
    • ogredog.com
Hello!
I recently replaced the stock yellow reject buttons on my coin door with the appropriately colored buttons for the players 1-4.
However, behind each reject button, there is a spring loaded, translucent RED plastic lever that the bulbs shine through.  This blocks a bit of the light AND tints all of my buttons slightly red.
Is there a source for CLEAR replacements for these parts?
« Last Edit: June 04, 2005, 11:06:47 am by tivogre »
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
Re: Source for CLEAR levers behind the reject button on coin door...
« Reply #1 on: June 04, 2005, 06:36:06 am »
If you don't mind my asking, where did you get the replacement buttons? I would like to do the same thing for my coin door.
-- Chris
Underway: Joey's Arcade
tivogre
    • ogredog.com
« Reply #2 on: June 04, 2005, 07:26:19 am »
-- Chris
No problem.
The reject buttons are from HAPPs here:
http://www.happcontrols.com/cc/420517xx.htm
And the Inserts:
http://www.happcontrols.com/cc/42008400.htm
Here is the result:
The only thing that will make it better is to get the clear levers, and then maybe some superbright LEDs...
CJK
Re: Source for CLEAR levers behind the reject button on coin door?
« Reply #3 on: June 04, 2005, 01:44:58 pm »
That looks MUCH better than all one color! (I can hear my wife groaning now, as I find yet ANOTHER thing to spend money on for this cabinet!)
Thanks for the info!
-- Chris
tivogre
    • ogredog.com
« Reply #4 on: June 05, 2005, 01:59:46 pm »
OK... If no one has a SOURCE for these, does anyone know what they're CALLED (proper name) so I can begin looking for them?
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #5 on: July 22, 2005, 05:17:29 pm »
Will these reject buttons fit a coin controls door?
