Author Topic: Fix TFT Flatscreen?  (Read 1244 times)
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
Fix TFT Flatscreen?
« on: June 03, 2005, 06:53:17 pm »
I pick up a TFT flatscreen monitor today for free :) but it doesnt work :(
its a Compaq TFT5000
When i press the power/standby button but it lights up momentarilly orange and then goes out
sometimes when the button is pressed the screen flashes white very quickly but then turns off
doesnt seem to be a switch issue
any ideas what it could be? a dead controller board?
is fixing it feasible? or not worth the cost
rchadd
  • Made in Cornwall
Re: Fix TFT Flatscreen?
« Reply #1 on: June 04, 2005, 02:42:43 pm »
is it feasible to get a replacement board or panel?
StephenH
« Reply #2 on: June 07, 2005, 03:19:37 am »
Some LCDs don't light up until you actually send a computer signal to them.  I would try maknig sure you are sending a signal, and that the computer you are sending from is not in sleep.
I would also see if there is potentially a backlight or a power supply problem.
