November 21, 2009, 07:28:40 AM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News:
   Home   Help Arcade Search Login Register
Main Woodworking Reviews Software Monitor/Video
Audio/Jukebox/MP3 Project Announcements Artwork Consoles Buy/Sell/Trade
Arcade Miscellaneous Everything Else Politics n Religion Forum Discussion Wiki Discussion
DOS/WinCab PowerMAME SK Jukebox UncleTs Jukebox Project Arcade
Linux Restorations Pinball MaLa Frontend
Recent posts | Arcade | Rules | Old Boards | Old Archives | Chatroom | Wiki | File Repository | RSS
Pages: [1]   Go Down
  Send this topic  |  Print
Author Topic: Custom Control panel designer  (Read 2707 times)
VMJ Team
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« on: June 03, 2005, 12:48:49 PM »
This is both a new service as well as software, so I have posted this in both forums.
Mameroom Designs LLC has released the latest in control panel designing software.  Design and layout your own customized control panel to build yourself or have us make a custom kit for you!  MameRoom Designs LLC will soon be using this software to manufacture custom control panels completely assembled and ready to plug-and-play!  Each panel will be custom made based on YOUR specifications!
http://www.mameroom.com/files/CPD_Setup.zip
Just a few of the new sofware features:
- Accurate control placement to .001"
- Can draw lines and circles.
- User can now specify the size of the control panel
- Select multiple controls for copying/deleting/moving
- Insert saved control configurations
- User can add controls to side (base) of control panel
- Parts catalogue of part numbers and prices
- Keeps a running total of the cost for added components
- Add backdrops and control panel overlays (see pics)
- Export to BMP, JPG, and DXF (imports into CAD)
- Specify measurements in inches or mm.
...much more and more to come!
(pic using the SPACE STATION control panel overlay)
(Adding controls to the side of the control panel)
Logged
Buddabing
Wiki Master
Trade Count: (0)
Full Member
Offline Offline
I'm a llama!
View Profile
« Reply #1 on: June 03, 2005, 12:54:32 PM »
Your product would be more of service to me if it could import from and export to comma-delimited files.
Logged
Please read the wiki!
VMJ Team
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #2 on: June 03, 2005, 01:00:42 PM »
explain more of exactly what you would like to see and we can throw it in there.
Logged
Buddabing
Wiki Master
Trade Count: (0)
Full Member
Offline Offline
I'm a llama!
View Profile
« Reply #3 on: June 04, 2005, 09:56:59 AM »
I'd like to see something I can use with my CPMaker utility. My CPMaker utility takes panel description files, along with the user's background image and pictures of the various controls, and creates an image with the currently non-active controls dimmed out, which is then (optionally, using my BuddaMAME build) displayed to the user when pause is pressed.
If you have a way to export a readable format, such as a comma-delimited file, that I can then convert into a CPMaker template, that would help a great deal. If you would like to share your artwork images, all the better.
If you're interested, I'd be glad to send you my documentation on my panel file layouts.
Regards,
Buddabing
Logged
VMJ Team
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #4 on: June 06, 2005, 06:59:41 AM »
Sure, I can add to the export and import of the CPD program.  Please send any documentation to sales@mameroom.com.
Logged
Lilwolf
Trade Count: (+1)
Full Member
Offline Offline
View Profile
« Reply #5 on: June 06, 2005, 11:47:30 AM »
You should add a testing feature for frankenpanels.
A hand moves and and swings back forth, up and down on the trackball.  And for the spinner move in and puts the other hand on the buttons....
basically so people can see that there will be an issue of that 4way sitting right infront of their trackball.
Shouldn't be all that hard to add (just animation of an image... motion based on the control type.)
Logged
VMJ Team
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #6 on: June 06, 2005, 11:49:14 AM »
Excellent suggestion!  I will add this to the program.
Logged
lokki
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #7 on: June 06, 2005, 01:40:02 PM »
I was unable to make a small size CP. (for a cocktail) look like the smallest size you allow are 10"
Would be nice if this where lower. Was trying to desing 9x6 cocktail CP
Logged
VMJ Team
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #8 on: June 06, 2005, 01:45:00 PM »
I didn't even think about cocktail cp's...I'll change this today!
Logged
VMJ Team
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #9 on: June 06, 2005, 01:50:58 PM »
You should be able to create cps as small as 5" now.  Please download the updated setup program.
Logged
markrvp
ARGHHHHHHHHHHHHH!!!!!!!!!! True Genius!
Wiki Contributor
Trade Count: (+4)
Full Member
Offline Offline
NFL Expert
View Profile
« Reply #10 on: June 06, 2005, 02:06:32 PM »
Once a control has been placed, I can't go back to it and drag it around, I have to manually enter the X & Y positions.  Is there a way to drag a control that is selected (highlighted in Cyan with the square in the middle)?
Logged
VMJ Team
Trade Count: (0)
Full Member
Offline Offline
View Profile WWW
« Reply #11 on: June 06, 2005, 02:10:27 PM »
Yes, I apoligize...I'm working on instructions.
Click once to grab the control to change it's properties (ie, color, options, x & y position).
Double-click to drag it around the layout screen.
Logged
lokki
Trade Count: (0)
Full Member
Offline Offline
View Profile
« Reply #12 on: June 06, 2005, 03:17:20 PM »
Logged
Pages: [1]   Go Up
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 | SMF © 2006-2009, Simple Machines LLC | Sitemap Valid XHTML 1.0! Valid CSS!
Page created in 0.15 seconds with 24 queries.
