Author Topic: Wiring question  (Read 1525 times)
isugoat
  • Last login:March 15, 2004, 10:46:51 pm
Wiring question
« on: December 08, 2002, 01:02:26 am »
i'm trying to clean up my panel's insides so i've got a few qustions.  i've got a Sidewinder hack, with the wires from the sidewinder going to a terminal then to the buttons.  i have it set up right now so that i have 9 or 10 different wires connected from the ground terminal going to the different buttons.  i could clean up a bit if i could just have one wire going from the ground terminal to button one, then daisy chain that to button 2, then to button 3 and so on...
here's a pic:
i have the top and want the bottom.  can i wire the ground wire this way?  will it have any effect on button response times? or will it work jthe same as the way i have it now?
thanks in advance
Larry Smith
  • Last login:September 01, 2004, 07:27:11 am
Re:Wiring question
« Reply #1 on: December 08, 2002, 11:20:53 am »
That will work fine. If you want a bit of fault tolerance, add one more wire from the end of the chain back to the Ground terminal. That way if there is a wire breaks they will still be grounded.
