Author Topic: Top Fire T-Stik  (Read 820 times)
NoOne=NBA=
Top Fire T-Stik
« on: June 02, 2005, 02:08:20 am »
I got tired of dismantling my Vindicator controllers tonight, and  successfully made a top-fire T-stik out of a T-stik Plus base, and a Top-fire Super handle.
The only modification I had to make to the handle was to add a second E-clip, to keep the stick from dropping in too deep.
You could use a spacer to do the same thing, but I didn't want to sacrifice any of my pieces to make one.
For the firing part, I just built a frame below the stick, and mounted a leaf switch on it, for the bottom plate on the firing mechanism to hit.
I'll post some pics tomorrow, showing what I did.
It's all "proof of theory" work, so the fit and finish isn't up to what I'd do on a final version--but it works beautifully.
The one thing that I haven't been able to do yet is get the top-fire to work AND keep the switch from the top though.
I have a few theories on that, that I may play with in the future.
AllisterFiend
  • Last login:June 04, 2013, 05:04:16 am
  • Rush 2112
    • Check out my Dragon's Lair/MAME cabinet.
Re: Top Fire T-Stik
« Reply #1 on: June 02, 2005, 05:35:04 am »
I look forward to your pics.  I've been waiting for someone to come out with a good top fire stick that has a design similar to the t-sticks.  Looks like I might have to try it myself.
Allister Fiend
NoOne=NBA=
Re: Top Fire T-Stik
« Reply #2 on: June 02, 2005, 06:57:05 pm »
Here are the pics of this.
The black line on the handle is where I shoved it all the way through, and marked it with a Sharpie, so I'd know how far to come down with the upper E-clip.
Grasshopper
  • Last login:March 04, 2025, 07:13:36 pm
Re: Top Fire T-Stik
« Reply #3 on: June 02, 2005, 07:11:59 pm »
Cool idea. Most of the IL handles appear to be interchangeable if you use spacers.
