Author Topic: wiring microwitches  (Read 1429 times)
Nefesis
  • Last login:August 25, 2007, 11:28:22 am
  • psst... star wars... it's the greatest!!!
wiring microwitches
« on: May 30, 2005, 11:40:35 am »
Hi. Will probably be wiring up my cabinet today after many months of inactivity, and was wondering how to thread the wire through the microswitch. I am using an I-PAC with controls from Ultimarc, and was wondering if I just thread the wire through the little holes at the ends of the metal parts coming out of the switches. I have attached a picture showing this.
ShinAce
  • Last login:January 16, 2007, 07:38:14 pm
  • Building the unbuildable since 2001
Re: wiring microwitches
« Reply #1 on: May 30, 2005, 12:38:22 pm »
You either crimp your STRANDED wire into a quick disconnect. You would use a red one, female at that, of 3/16" size.
Or you can just solder your wire to the tab, in which case any type of wire will do.
An ounce of image is worth a pound of performance.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: May 30, 2005, 01:07:00 pm »
... though if you solder, and you're bad at soldering, an dyou heat up the tab for too long, you will melt stuff.
 :D
NO MORE!!
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
« Reply #3 on: May 30, 2005, 02:12:39 pm »
I'd vote for the quick disconnect option, as you will likely end up having to desolder too many connections when you decide to rearrange your panel later.  :-)
-- Chris
Underway: Joey's Arcade
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
« Reply #4 on: May 30, 2005, 05:05:28 pm »
Microwitches should never be wired. They should be burned at very small stakes!
(Use disconnects)
ShinAce
« Reply #5 on: May 30, 2005, 09:03:02 pm »
Better yet, get completely non-insulated disconnects and solder your wire to THAT!!!
