Author Topic: power for LED's???  (Read 3502 times)
REBIRTH
  • Last login:December 28, 2023, 09:10:29 pm
  • What is that?
    • REBIRTH "Rotating Arcade"
power for LED's???
« on: December 06, 2002, 01:44:01 am »
I'm sure a simple question - I'm just not seeing it.  I have an IPAC (no LED harness) and Opti-Pac.  I have a translucent trackball for which I want to hook up a couple of LED's to illuminate.  They apparently need a 5V source, which I know the IPAC/OptiPAC uses as power as well... Using them, or something else, where can I get a constant 5V source to light the two LED's?
Thanks!!!!!!!!
:) Rotate or die! :)
cdbrown
  • Bowowow
Re:power for LED's???
« Reply #1 on: December 06, 2002, 02:07:02 am »
Your computer power source has +5V (red wire), just make sure you have a resistor before the LED.  This has been discussed a few times http://www.arcadecontrols.org/yabbse/index.php?board=1;action=display;threadid=663;start=0
Cheers
-cdbrown
REBIRTH
  • What is that?
« Reply #2 on: December 06, 2002, 02:13:59 am »
Perfect, thanks!  I did search before I posted, but obviously I didn't search too well.
Thanks again! :o
Smittydc
  • Last login:October 05, 2008, 12:48:10 am
  • because its fun!
« Reply #3 on: December 12, 2002, 05:12:56 pm »
You might try picking up one of the led clusters available here.  Should provide tons of light and come with an adapter for attaching to computer 12v power supply:
http://www.glowire.com/
Build a man a fire, he's warm for a night.  Set a man on fire, he's warm the rest of his life.
REBIRTH
  • What is that?
« Reply #4 on: December 12, 2002, 11:06:46 pm »
wow - that looks perfect!  Thanks!
slug54
  • Last login:June 12, 2014, 09:00:21 pm
  • Man, I hope this cab fits through the door way!
    • Arcade Extreme
« Reply #5 on: December 13, 2002, 07:28:45 pm »
The Opti-pac has terminals labeled 5v and ground.
I just used these and added a current limiting resistor
it works great and illuminated the trackball perfectly.
                            Slug54
