Author Topic: Mounting Happs Super to 3/4" Wood  (Read 3288 times)
mcleanjoel
  • Last login:May 26, 2005, 06:56:52 am
« on: December 05, 2002, 07:28:06 am »
I see many control panels are routed to make the joystick taller.
My question is - are the people who are routing using the taller spacer that is designed for wood control panels or are they routing because they don't have that spacer?
I know it is a matter of preference but does the longer spacer accomplish getting the joystick to a "standard" height in a 3/4" panel?
gtjoe
  • Last login:November 04, 2006, 05:06:20 pm
Re:Mounting Happs Super to 3/4" Wood
« Reply #1 on: December 05, 2002, 03:20:36 pm »
Tall spacer is only a 1/4" taller than the short spacer, so I guess your answer is no.
joystick height above 3/4" panel surface to top of joystick
Super with short spacer, no routing =  2 3/8"
Super with long spacer, no routing   = 2 5/8"
Competition, no routing 2 5/8
Bat handle section is 2"
When I had the supers, I actually used the shorter spacer, so I could reach the reverse button easier for defender.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: December 05, 2002, 05:01:32 pm »
I agree.  3/4" wood vs 1/16" metal is not "fixed" by a 1/4" longer spacer.
I suggest routing out ~1/4" to 3/8" of the wood and using the longer spacer.
Robin
Knowledge is Power
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #3 on: December 05, 2002, 06:38:00 pm »
I have heard that mounting a super to 3/4" wood can result in less responsive diagonals unless routed?  It was on an older thread of this forum I believe...  any truth to it?
eightbit
  • My cab is never done...
« Reply #4 on: December 05, 2002, 07:05:08 pm »
I don't see how it could....  ???
StingMe
  • Last login:December 18, 2002, 02:30:38 pm
  • * Ouch! *
« Reply #5 on: December 05, 2002, 08:29:43 pm »
The stick has to travel a bit further for diagonals and may be restricted somewhat by the cp thickness and the size of the hole...with a thicker cp the hole may have to be enlarged to avoid this type of response problems.
Oscar joystick mounting plates work like a charm.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #6 on: December 06, 2002, 12:38:10 am »
I have a 3/4" control panel with happs supers (using the tall spacer) and its perfect.  I wouldn't want it any taller.
Now my control panel is exactly 3/4" thick (with just some black pica vinyl on top).  Are these problems happening for people who have a 3/4" panel with lexin/plexiglass on top?
« Last Edit: December 06, 2002, 03:10:41 am by Dave_K. »
SNAAAKE
  • -Banned-
« Reply #7 on: December 06, 2002, 02:58:41 am »
EXACTLY dave, ;)
You only route the bottom when you are using plexi or lexan.supers are perfect for 3/4" wood without anything in top of the panel.
mcleanjoel
« Reply #8 on: December 06, 2002, 06:45:22 am »
Sounds like there really are differences in preference as Gtjoe made his shorter with the short spacer to reach a button with his thumb while others are using the long spacer AND routing to get some height.
I think the argument that a 1/4" longer spacer does not equal the difference between metal and 3/4" wood makes sense but it also sounds like many are happy without routing so I'll probably go that way since I am lazy!
Question: If you are not routing - are you still using the same size hole as the buttons or would slightly larger be better to make sure movement is not restricted?
SNAAAKE
  • -Banned-
« Reply #9 on: December 06, 2002, 08:38:14 am »
no biggie..the problem is less then nothing if you are not using any plexi or lexan on your panel.plays fine. :)
electricd
  • Last login:February 14, 2025, 07:59:10 pm
  • I'm not a llama!
« Reply #10 on: December 06, 2002, 09:16:24 am »
mcleanjoel:
I used a slightly larger hole for the joysticks then I did for the buttons.  I believe it was 1 1/4" for the joysticks if i remember correctly.  It did work out perfect though.
ED7
darkmanx
  • Last login:May 29, 2003, 04:46:57 am
« Reply #11 on: December 09, 2002, 08:36:59 pm »
i used the same hole saw as i did for buttons and it is perfect. i suggest you do that and make it bigger if needed. you cant un-cut a hole...
WHELP! As if you knew what an eternity was. Grovel before your true master!
