Author Topic: WinGun Guncon2 Driver Project  (Read 76875 times)
mike boss
Re: WinGun Guncon2 Driver Project
« Reply #80 on: June 14, 2011, 08:56:35 pm »
Got this installed and started to configure.
It's a real pain in the a**.
Using a TV my resolution is only 800x600, so I can't really read text.
I think I'll need to set it up with the TV and PC Monitor @ the same time.
Gun2 is working ok, gun1 not so much.
Even gun2 the calibration and movement is way off.
It appears to be stuck in the middle.
mike boss
« Reply #81 on: June 15, 2011, 05:56:30 pm »
Going to try Smogs driver.
Can anyone tell me, do I install the driver then plug in the guns ?
mike boss
« Reply #82 on: June 15, 2011, 07:04:37 pm »
Tried Acorn's driver but it kept getting stuck in the calibration mode. It would not move beyond that step, I waited several minutes.
I've moved onto Smog's driver, but it wont see the guns.
When the guns are plugged in they install via windows, but that's where it stops.
Am I missing something ? Any tips, tricks ? Help ?
caskad
  • Last login:April 02, 2012, 02:48:22 am
« Reply #83 on: September 29, 2011, 02:12:12 am »
Hello,
just trying to get my guncon namco np106 to work with wingun on my mj25.. perfect :)
but one question:
looking for great guns with recoil like "desert eagle" but it seem there have just normal Ps2 port, but compatibility with guncon2.
So does it work with an USB adaptator? ;D
thanks !
Edit:
Model 2 emulator issue, can't reload even with right mouse emulated on various button.  Any idea?
« Last Edit: September 29, 2011, 11:54:09 am by caskad »
mike boss
« Reply #84 on: March 25, 2012, 08:53:15 pm »
Any current links to smogs driver ?
Having no luck finding it.
Arnold101
  • Last login:June 19, 2025, 01:56:35 am
« Reply #85 on: May 11, 2012, 05:51:05 pm »
i've installed joytech sharpshooter 2 fine but the gun is not detected :(
eldiego
  • Last login:June 07, 2024, 11:18:22 pm
  • I do my daytona twin, arcade 4 players and vpin!!!
« Reply #86 on: April 30, 2018, 06:12:17 pm »
I try wingun with my w7 x64 and not install correctly and not recognize my guncon2. Previously i try with guncon2pc driver, i used this with my previous cabinet with xp and works fine but in w7 x64 did not work.
There is another driver for x64?
