Author Topic: wtb 3 Wing Slot Cutter Assembly - 1/16" Slot #38  (Read 5504 times)
daywane
  • GRRRR!
« on: May 22, 2005, 11:59:05 am »
T-Molding slot cutter assembly for a router.
Includes arbor, bearing, cutter, and nut.
Use with molding 3/4" wide and smaller.
Shank Diameter: 1/4" (shaft width)
Cutter Height: 1/16" (slot width)
Price: $ 27.95  from T- molding.com
Not a bad price  but I will only use it a few and figured I can save a buck or two and buy a used one
I just got a router for $10.00 ( found it in a trunk of a car about to be crushed! works great
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
NeeBick
  • Last login:April 15, 2011, 01:14:02 am
Re: wtb 3 Wing Slot Cutter Assembly - 1/16" Slot #38
« Reply #2 on: May 23, 2005, 05:45:59 pm »
Searching froogle turned up this:
http://www.routerbitworld.com/product_info.php?products_id=18426
has a 1/2'' shank though...
Xphile
  • Last login:July 03, 2010, 12:54:48 am
  • I'll never go back to the NHL!
Pull a year and a half strike- it's over 4eva..
besides, WHL rocks!
crashwg
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
MonitorGuru
« Reply #5 on: May 24, 2005, 09:57:31 am »
1/4"
http://routerbitworld.com/product_info.php/cPath/1236_1237_1320_1328/products_id/18418
I would never get this one... you'd never be able to make a straight cut.. You need the spinning disc, not the single pencil tip cutter like this one.
NeeBick
« Reply #6 on: May 24, 2005, 11:52:57 am »
1/4"
from the page:
"Includes three wing slotting cutter"
I think you were looking at the "Customers who bought this product also purchased" section
I got confused at first also (I need my pictures  ;D)
KenToad
  • Last login:December 18, 2025, 09:36:23 pm
  • Flap Flap Flap
« Reply #7 on: May 24, 2005, 12:08:47 pm »
I just bought the MCLS bit (see Crashwg's post) for 16 bucks with free shipping.  It took about four days before I got it, but no problems, used it and worked great, although I have no previous experience to compare.
Cheers,
KenToad
nostrebor
  • Not enough wit to effectively use this space...
  • Last login:October 04, 2013, 02:02:41 pm
  • SHOCKING!!
« Reply #8 on: May 24, 2005, 02:41:29 pm »
MLCS all the way - Best price period for these.
MonitorGuru
« Reply #9 on: May 24, 2005, 03:35:36 pm »
Whats the standard cut depth on the MLCS ones?  I borrowed a 4 wing version from a friend and it cuts about 2.5 times the depth of the Tmolding spine... WAY too much, and would weaken or break out the particle board, especially if you've dado'd the cross pieces like the front with coin door right behind the Tmolding channel.
nostrebor
  • SHOCKING!!
« Reply #10 on: May 24, 2005, 05:15:02 pm »
According to MLCS website, depth of cut is 1/2" for the 3-wing cutter, if used with their bearing and arbor.
Having used these extensively, I have had zero problems with weakness or breaking, and I dado all joints.
Avery
  • Last login:May 03, 2013, 12:52:02 am
  • Have fun! Make stuff.
« Reply #11 on: May 24, 2005, 06:06:43 pm »
I borrowed a 4 wing version from a friend and it cuts about 2.5 times the depth of the Tmolding spine... WAY too much....
You can fix this either by using a larger bearing with the bit or, depending on the cuts you have to make (curves=bad) and the diameter of the cutter, by using a fence that attaches to the router.
Of course if your friend doesn't have a bearing kit and you have curves to deal with, you might just want to go buy the MCLS bit.
Avery
daywane
  • GRRRR!
« Reply #12 on: May 25, 2005, 08:32:51 am »
thanks guys. taken me a bit of doing to log on.
fighting spyware. ( a mean one!!!)
spybot dont even see it
pc pitstop don't see it.
I sure do!  ::)
if no one hears from me in a few days I am formating my sytem!
AmericanDemon
  • Last login:September 22, 2019, 11:08:03 pm
  • Still an AmericanDemon
« Reply #13 on: May 25, 2005, 09:02:23 am »
get ad aware se from download.com it should help out.  also update your version of spybot search & destroy.
daywane
  • GRRRR!
« Reply #14 on: May 25, 2005, 04:08:36 pm »
beat ya to it.  ;)
I did have ad aware but seems like something just smacked it silly.
downloaded a fresh install and seems to have got rid of my problem.
that was a nasty bug. >:(
SNAAKE
  • Trade Count: (+29)
« Reply #15 on: August 09, 2005, 12:38:09 pm »
UH..BUMP!
Whats the difference between 1/2" and 1/4" skank(LOL) ?? I bought a ruby router from home depot but I am not sure which bit to order from MLC.Confused on the skank part ???
pointdablame
« Reply #16 on: August 09, 2005, 12:42:51 pm »
A router will have either a 1/4" shank or 1/2"  A 1/2" router can accept either a 1/4" OR 1/2" but obviously not the other way around.
Just check what your router accepts.. it'll be on the box or in the manuals.
first off your and idiot
nickbuol
  • Last login:July 22, 2025, 09:55:45 pm
  • 2nd Time Around
« Reply #17 on: August 09, 2005, 10:15:54 pm »
Yeah, the shank in the rounded part that you actually "stick" into the router.
Oh, and I'll give another vote for MCLS.  I borrowed a slot cutter and router when I built my first cabinet in 1998, but this time around, I had my own router, and a slot cutter from MCLS.  Worked awesome.  No problems at all with t-molding staying put or anything.
I am helping 2 other guys with cabinets that they are going to be starting in a month or so, otherwise I would just sell you mine for cheap...
Nick
