Author Topic: Arcade button for computer on  (Read 3291 times)
arcadeboy0000
  • Last login:August 10, 2005, 10:34:12 pm
« on: May 21, 2005, 09:11:14 pm »
Hey everyone. How can I convert an arcade button (cherry switch) to a computer on button? Should I cut the wire from the computer power on and splice it together with longer wires to attach to the button? If so, is it as simple as attaching the white ground wire to the ground of the cherry switch and the other colored wire to the normally open?
grueinthebox
  • Last login:February 07, 2014, 12:37:03 pm
  • Feed your head.
    • red42.com
Re: Arcade button for computer on
« Reply #1 on: May 21, 2005, 09:35:18 pm »
Yup, it's just that simple.
"All right. It's Saturday night. I've got no date, a two liter bottle of Shasta, and my all Rush mix tape. Let's rock!"
krick
  • Gotta have blue hair.
« Reply #2 on: May 21, 2005, 11:00:45 pm »
I picked up a push button switch from radio shack (see below) and mounted it in spot where my cabinet originally had a toggle switch.  One press turns on my computer, another press shuts down my computer.  I put a Vantec ION 400B power supply (also see below) in my PC that has a switched AC outlet on the back.  I've plugged the cabinet power cord (powers the monitor and marquee) into that outlet and it switches on and off with the PC.
RadioShack Momentary Switch
Normally open. Includes one red and one black. Pkg. of 2
Catalog #: 275-609
$3.29
http://www.radioshack.com/product/index.jsp?productId=2062496
http://www.vantecusa.com/p_van_400b.html
« Last Edit: March 04, 2006, 03:59:31 pm by krick »
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
testicle187
  • Last login:January 02, 2026, 03:45:34 pm
« Reply #3 on: May 21, 2005, 11:04:01 pm »
You can use a harness connector like the one coming from a CDDA cable that comes with CD-ROM drives, so you don't have to splice your actual cable from your case.
Joystick Jerk
  • Last login:June 26, 2024, 05:10:33 pm
  • Slave to the stick.
« Reply #4 on: May 21, 2005, 11:29:54 pm »
Also check the BIOS options for your mobo, as many have an option to active the PC with a keypress, and then you simply have to bind that assigned key to your chosen arcade button.
arcadeboy0000
« Reply #5 on: May 22, 2005, 06:28:23 am »
Thanks for the suggestions guys!
