Author Topic: Homade degausing coil question  (Read 1252 times)
shmokes
  • Don't tread on me.
    • Jake Moses
« on: May 19, 2005, 12:47:31 am »
I was at my friend's house the other day and noticed that his TV (about a 30 inch wide-screen tube-based HDTV) had a purple spot in the corner.  I remembered back to seeing these instructions for making and using a homeade degaussing coil and decided I would make one to cure his TV.
Should I worry at all about messing his TV up, though?  I've never done this and won't even attempt it if I might possibly make the problem worse.  Is there any reason an HDTV would react any differently to a degaussing coil than a standard def TV?  What about a widescreen?
Essentially do I have anything to worry about or can I just make the thing and go fix his TV?
Oh yeah...and can I just use a regular arcade pushbutton or do I need something that is made for a lot more electricity to be flowing through it?
Additionally, does anyone have an idea of what wattage lightbulb I should use?
thanks
« Last Edit: May 19, 2005, 01:38:36 am by shmokes »
Best Kid iPad Apps
HoopstarsGarage
  • Scratch Building Demi-God!
  • Last login:April 19, 2016, 09:24:11 pm
  • Scratch Building Demi-God..
    • Hoopstars Garage
Re: Homade degausing coil question
« Reply #1 on: May 20, 2005, 08:31:28 am »
nothing that isn't reversable..
shmokes
    • Jake Moses
« Reply #2 on: May 20, 2005, 11:18:21 pm »
That inspires confidence, lol   ;)
Best Kid iPad Apps
