Author Topic: Construction Issues  (Read 6174 times)
Big_Daddy
  • Last login:May 28, 2006, 03:55:03 pm
  • Beatmania and MAME!! First cab in progress...
Construction Issues
« on: May 17, 2005, 01:44:54 pm »
I've been working on my Project Arcade cabinet intently after purchasing the book.
I'm making a Project Arcade cab.
Shape D.
  • Last login:July 05, 2012, 06:17:57 pm
  • >Look at me, I'm a Newbie<
Re: Construction Issues
« Reply #1 on: May 17, 2005, 02:01:37 pm »
patience is the key to victory.
Hey Baby, Have you ever met a Newbie with 38 pages of previous posts before? Do you Want to?
slayj
  • Last login:January 10, 2006, 02:49:56 pm
  • Anybody seen my joy...???!
« Reply #2 on: May 17, 2005, 04:49:02 pm »
I had the same problem except that I was using hot glue in the middle of winter.  I would put the glue down and it would harden before the 2x2 ever touched it.  :laugh: So I clamped the pieces down, drilled, and screwed.  After you drill, you can go back and add glue before you screw them in for added support.  If your clamps do not have the reach to properly hold the piece in place you will have to rig something up.  I ended up clamping a piece of wood on each side and then clamped them to the piece I was setting.  Hard to describe, but it worked.
Did you know if a frog had wings it wouldnt bump its butt!!!
Big_Daddy
« Reply #3 on: May 19, 2005, 01:45:24 pm »
Thanks a lot for all the help!  I'm making great progress now!  Patience was the answer.  I just needed to wait a bit longer for the glue to fully harden.  Thanks!
JONTHEBOMB
  • Last login:March 28, 2025, 11:39:04 pm
  • BOOM!!!!
« Reply #4 on: December 22, 2005, 12:31:30 am »
I wish I had seen this sooner.  This problem with hot glue was driving me crazy while I was trying to glue the base plates and lower supports to the base.  I ended up using wood glue and clamps.  This worked well, but I would suggest letting the wood glue dry over night.
metaHipster
  • Last login:January 10, 2010, 06:09:19 pm
  • Taking the next level to the next level
    • MetaHipster's Arcade Blog
« Reply #5 on: February 08, 2006, 08:50:14 pm »
god bless clamps.  yet i never seem to have enough :)
