Author Topic: Should I fix this?  (Read 2409 times)
monkeybomb
  • PM me to find out how to get a custom title like mine!
  • Last login:January 03, 2018, 07:16:29 pm
Should I fix this?
« on: May 12, 2005, 12:27:15 pm »
I have a monitor that came in a very cheap dynamo cabinet.  I thought it would be fixable but I realy have no clue.  There are 2 problems.
1.  imagine a layer of water over the monitor with a wave maker at the bottom.  it is consistantly making wate movements.  This is different than just a line scrolling from bottom to top, it is creating waves.
2. there is a purple spot in the upper left corner.  Degaused it with the button and manually and it was no help.
SirPeale
  • Green Mountain Man
Re: Should I fix this?
« Reply #1 on: May 12, 2005, 01:00:28 pm »
Pictures, please.  And make/model of the monitor.
monkeybomb
« Reply #2 on: May 12, 2005, 01:04:09 pm »
DOH! it will have to wait til tomorrow.
monkeybomb
« Reply #3 on: May 13, 2005, 12:51:34 am »
Okay, this is the best I could do for pics.  It's a shot of the purple in the corner and the back of the monitor for model.  The thing that has me wondering if I should try to fix it is the under water effect and I can't figure out a way to take a picture of that.
Ken Layton
  • Guru
  • Technician
« Reply #4 on: May 13, 2005, 01:22:30 am »
Cabinet speaker magnet and/or the fluorescent light ballast could be affecting the corner color.
MonitorGuru
« Reply #5 on: May 13, 2005, 09:43:18 am »
Concur with Ken....  But I have to ask this... Where are the convergence magnets on the neck of the tube???  That's a pretty dang long neck, and unless I'm getting really old, I can't make out any convergence rings on it!
monkeybomb
« Reply #6 on: May 13, 2005, 01:03:28 pm »
I'm not sure what convergence magnets are. :-[  I'm also not sure of the make and model of the monitor.  I'm completely new to monitors but would realy like to fix it myself if it can be done within a reasonable price.  I am aware of the risk and have read how to discharge the monitor a million times.
But the only acctual I have read much about is a cap kit.  If that, or something without much cost, might solve my problems then I'll give it a shot.  I really want to know if there is a point in tring to go for it.  If I start I will most likely become obsessed so I am cautious about starting any real repair.
If I am not able to remove the purple spot by changing the speaker with one that I know is sheilded, might it be fixed with a cap kit?
Also would a cap kit most likely solve the waves that flow over the monitor?
Can I take pictures of these waves some how?  It's seems impossable to take a still of movement.
Is there a chance one of these problems is just unfixable?
What monitor might I have?
If you can't tell what area of the monitor do you need better pictures of?
I hope these are better questions.
Prizmdrop
  • Last login:September 23, 2005, 05:52:05 pm
  • Must get a Naomi+GDrom!
« Reply #7 on: May 31, 2005, 06:58:01 pm »
Bump.....I'll be taking this cabinet on thursday, and need some advice on this thing. Are the symptoms that monkey speaks of fixable with a cap? Thanks for the help everyone, its very appreciated.
Q*Bert_OP
  • Oh yes, we did!
« Reply #8 on: June 07, 2005, 02:49:00 pm »
One of my TVs has that same wave and so do many games at my local arcades.
MonitorGuru
« Reply #9 on: June 07, 2005, 04:44:38 pm »
That appears to be a new Wei-Ya 826H replacement chassis connected to the tube.
If you are seeing a wave, it's likely you don't have an RF noise filter on your incoming AC line (before it goes to the isolation transformer) and/or you have the isolation transformer (or other transformers) located way too close to the monitor.
E.g. my Electrohome G07 has a nice wave in it in my Ms.Pac cocktail because the 2 AC transformers are about 1" from the neckboard, while the G07 in my upright Pac-Man is wave free as it's about 2 feet from the transformer board. (Yes, both have cleaned edge connectors and fuse blocks :) )
And I *still* cannot see the convergence rings on that tube... I'm VERY confused by that.  This is what convergence rings look like:
