Author Topic: How to install HappControls Bezel and Plexi?  (Read 1710 times)
Reg
  • Last login:April 27, 2004, 10:43:45 pm
« on: December 01, 2002, 06:41:02 pm »
Hi,
How do you install the HappControl bezel and Plexi on a
Cabinet that was based on Lusid blueprint?
I will like to make a genuine Look as possible...
thanks
Reg
Lindner24
  • Last login:May 20, 2008, 10:06:12 pm
Re:How to install HappControls Bezel and Plexi?
« Reply #1 on: December 02, 2002, 11:14:46 pm »
This is how I set up one of my projects...
I used Aluminum "U" channel and some foam weather stripping. (The peel and stick stuff)
-Drill some mounting holes in the U channel.
-Paint or tape the top of the U channel black.
  (Black Electrical tape is the easiest and it actually looks really good)
-Stick the insulation on both sides, inside the U channel.
-Screw into place with some flat screws
Get the foam a little less narrow than the U channel,
 so it doesn't stick out when compressed.
Also, Be careful cutting your plexi and bezel,
 leave clearance for the screws.
