Author Topic: Fiberoptics as t-molding??  (Read 2607 times)
Kingspinner
  • Last login:September 12, 2007, 08:37:52 pm
  • The King has Entered the FORUM!
« on: May 09, 2005, 08:07:29 pm »
Has anyone tried using fiber optics in their cab (especially cocktail ones) effectively? I would like... and this may sound strange... to use it as an alternative to t-molding around a 3/4" smoked glass top. any ideas? You all rock, so I know I will get some great feedback!
pointdablame
Re: Fiberoptics as t-molding??
« Reply #1 on: May 09, 2005, 08:19:59 pm »
Fiber optics (to my knowledge at least) dispense light through the ends of the fiber, and not the length of it.  You would need to have hundreds (thousands?) of fibers all pointing out, as well as quite a large light source for it to be effective.
first off your and idiot
AlanS17
    • AlanS17
« Reply #2 on: May 09, 2005, 08:33:51 pm »
Maybe you're looking for electro-luminescent (EL) tape.
pointdablame
« Reply #3 on: May 09, 2005, 08:39:27 pm »
yeah, GLO-Wire, EL wire, or EL tape would be much better alternatives.
Kingspinner
« Reply #4 on: May 09, 2005, 09:40:01 pm »
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #5 on: May 09, 2005, 10:14:29 pm »
WOW that is one hideous "website."
IMO, that much light might get distracting, but it sure would look cool.
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #6 on: May 09, 2005, 10:21:38 pm »
Couldnt agree more!  Sounds like an opertunity for me!  But anyway, Id go for some glow wire or something.
pointdablame
« Reply #7 on: May 09, 2005, 10:40:32 pm »
wow. that's pretty pricy stuff.   And couple that with the fact that they want you to use a 150 watt metal halide bulb.... your cabinet is going to get HOT FAST!!!
EL wire is much cheaper, easier to use/cut/apply, uses a LOT less power, and creates almost no heat.
Personally, I still don't see any reason to use this other than the "hey I used fiber optics" factor.  It's a good idea, but there are much better alternatives.
JDSkydiver
  • Last login:March 09, 2006, 06:28:35 pm
  • Go Irish!
« Reply #8 on: May 10, 2005, 10:33:14 am »
I agree...
I'd think using a "neon-esque" flourescent list just under the lip of the CP might give a nice "ground effect" look.
But IMO, the Fiber optics might be a bit much...
But what do I know...?
JDSkydiver
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #9 on: May 10, 2005, 12:03:03 pm »
I can't help dropping this website every time someone points out a bad website.  This is the place where I ordered my T-molding.  It was over a year ago and the website is still the same.  Really awful.  Your eyes will bleed.
Sorry for the hijack...kind of.
Best Kid iPad Apps
Elfman
  • Last login:February 01, 2012, 05:58:11 pm
  • Cabinet done! CP Done! Just tweaks left to do.
    • My Corner of the World
« Reply #10 on: May 10, 2005, 12:44:02 pm »
Fat_Trucker
  • Last login:September 08, 2010, 11:44:22 am
« Reply #11 on: May 10, 2005, 01:45:49 pm »
This stuff is probably what you are looking for.
Its not too pricey (dependent on the size of your cab).
Using it to replace t-moulding probably isn't the best idea since t-moulding also protects the edges of your cab as well as making it look pretty.
Its good for mounting inside things like speaker grills and the like though, and you could easily route a groove to mount it around the edge of your CP and Marquee or whatever.
Its 12v so should run directly from a 12v output like the ones on your PC power supply.
« Last Edit: May 10, 2005, 01:48:00 pm by Fat_Trucker »
I didn't touch it....honest!
Elfman
« Reply #12 on: May 10, 2005, 01:57:40 pm »
That would work really well if you could find someone who made clear T-moilding.  Just make your slot a little deeper, lay the neon and then put clear T-molding on it.  Just need to find someone who makes clear T-molding now and you are all set.
NIVO
« Reply #13 on: May 10, 2005, 02:15:47 pm »
clear corner guards will do the trick as well. Some modification may be needed in order to fit right. This idea has been discussed long ago in the chat forums by myelf and several others. (see what u miss!?)
Kingspinner
« Reply #14 on: May 12, 2005, 07:20:35 pm »
As I said at the beginning.. you guys do rock!
NIVO
« Reply #15 on: May 13, 2005, 06:56:19 pm »
you are gonna call this machine "VEGAS" right?  :P
Kingspinner
« Reply #16 on: May 13, 2005, 07:05:03 pm »
I may as well! :D I will be making the frame with weekend (minus the top for now)
