Author Topic: Arcade-related directory - myarcade.org  (Read 3183 times)
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« on: May 09, 2005, 01:42:32 pm »
Hey all,
  I just want to make an informal announcement to direct a little attention to one of my new projects..  I'm trying to harvest arcade-related websites and compile them into a directory-style layout.  It started out as a way for me to keep my bookmarks organized but once I got started I realized it could be so much more!
  Take a look at what I have so far at myarcade.org and let me know if you have any links to add to it (and you'll see my other related WIP announcement  ;D ).  Eventually I'll make it searchable and have a form for anyone to add a link, but for now I'm just getting it started :)
  Post here, PM me, or email me with a URL and category and I'll add it ASAP!
-sab
P.S. I don't want this to necessarily have project examples since these are already on AC's example page, but I will start putting project example links on there if you guys think it's worth it and I get enough of them. What do you think, would it be worth it to have a project example section with a brief description of each?
AlanS17
    • AlanS17
Re: Arcade-related directory - myarcade.org
« Reply #1 on: May 09, 2005, 05:28:49 pm »
Is this for BYOAC or general arcade?
screaming
  • Registered lUser
« Reply #2 on: May 10, 2005, 08:49:49 am »
  Hm.  Initially I was thinking it would have only BYOAC links since that's all I have.  I never considered having all "arcade related" links in there.  A *lot* of sites have information helpful to both types of projects, so I guess general arcade?
AlanS17
    • AlanS17
« Reply #3 on: May 10, 2005, 12:11:57 pm »
It entirely up to you. It's your site. The name sounds like general arcade links, but that wasn't your initial focus, and it would be a much more difficult site to maintain. There's a lot more arcade stuff than BYOAC stuff out there.
screaming
  • Registered lUser
« Reply #4 on: May 10, 2005, 12:24:12 pm »
  Yeah, I think it would be most helpful for it to be "general arcade" than specific to build-your-own arcade.   If it starts getting hard to wade through links that wouldn't be so beneficial for one group or the other I'll just do a little re-organization of the categories.
  I don't think that will be a problem for a long while though, if ever.
-sab
AlanS17
    • AlanS17
« Reply #5 on: May 10, 2005, 12:27:50 pm »
With a good directory structure like Yahoo USED to have, that shouldn't be a big problem. The sheer number of possible links could become a hassle, though.
screaming
  • Registered lUser
« Reply #6 on: May 10, 2005, 12:51:36 pm »
This is (and will always be) a community-driven site, so if you have any suggestions on a directory structure I'll see what I can do.
  Where are these alleged "links"? I added a form so you can submit them :)
AlanS17
    • AlanS17
« Reply #7 on: May 10, 2005, 01:02:52 pm »
Links submission? Sounds dangerous. Who's going to verify broken links? This site has had that problem before.
screaming
  • Registered lUser
« Reply #8 on: May 10, 2005, 01:09:50 pm »
  It's a manual process by me for now, at least until I get the organization and category layout stable enough.  I suspect there will be a little ramp-up time that will keep me pretty busy adding links for a while, then after that things will start to slow down once the more popular links get added.   Most of the links that are on there now have been up for quite a while... as long as I've been here, anyway.
  I have a cron job set up to do the broken-link pruning, but depending on how big the directory gets that might need to be re-worked.  I'll cross that bridge when I get to it :)
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« Reply #9 on: May 10, 2005, 01:18:48 pm »
Great idea! Any chance of comments for each link? Might be nice for people to add a few words about what they like/dislike about each link.
Crazy Cooter
  • Last login:August 19, 2025, 11:29:13 pm
« Reply #10 on: May 10, 2005, 01:32:52 pm »
When I used to use FrontPage 98, it had a link verification process built into it.  I don't know what you're using, but if it's WYSIWYG, it may have that.
screaming
  • Registered lUser
« Reply #11 on: May 10, 2005, 04:13:35 pm »
  Added.  We'll see if it gets much use...
  I added a "rating" system that's exactly like E-Bay's.  In fact, I "stole" their icons :) I figured that might be a nice touch..
-sab
« Last Edit: May 10, 2005, 04:17:01 pm by screaming »
screaming
  • Registered lUser
« Reply #12 on: May 10, 2005, 04:15:51 pm »
  Thanks for the tip!  I'm not sure Frontpage will work though since the data is mostly database-driven.  I don't have to make a page for every single category, I just give my backend software a template to use and it takes care of everything else..
  I know they make Windows-based tools that will crawl pages looking for dead links though... Hmm..
*shrug*
-sab
AlanS17
    • AlanS17
« Reply #13 on: May 10, 2005, 06:53:23 pm »
EndTwist
  • Last login:May 26, 2022, 05:04:49 pm
  • Arg.
« Reply #14 on: May 10, 2005, 09:36:12 pm »
You might want to get some people who are willing to verify links (like "myArcade Moderators"). This way not all the work falls on you.
Also - you might want to come up with a slightly better design (no offense meant, it just isn't that great, especially on larger resolutions).
Lastly - take a look at mod_rewrite if your host supports it (see: http://www.sitepoint.com/article/guide-url-rewriting). It'll make your url's even cleaner (instead of "http://www.myarcade.org/?lc=DOS+JBs", you could have "http://www.myarcade.org/DOS-JBs/" or "http://www.myarcade.org/DOS-JBs.html", but it will still use your script)
screaming
  • Registered lUser
« Reply #15 on: May 11, 2005, 07:27:41 am »
  I'll definitely be looking for people to help out once everything gets rolling, especially now that there are comments to moderate too.  It's not 100% set up yet though and I haven't gotten too many submissions, so I'm okay for now.
  I should have a formal announcement for both the directory and the hosting by this weekend.   Once I get that out it'll pick up, and then I'll re-evaluate how much moderation is needed.
  Yeah, I know I'm a horrible design guy.. I try and stick to the technical stuff :)  If you (or anyone else) wants to come up with a better design, I'll be sure to implement it!  I'll see what I can do for higher resolutions in the meantime.
  Yeah, one of the speedbumps I hit when setting this up is my provider switched me to a Windows box (IIS) right in the middle of me setting this up.  I'm still looking for a more elegant solution (like mod_rewrite) than creating virtual directories for each category...  Once I find one I'll be sure to implement it!
  Thanks for the suggestions, EndTwist!
-sab
P.S.  Thanks AlanS17 for making the first comment :)
JoyMonkey
    • JoyMonkey.com
« Reply #16 on: May 11, 2005, 07:34:43 am »
Hows abouts listing the most recent comments on the main page?
OOh! Ooh! And an obligatory 'highest rated' section.
screaming
  • Registered lUser
« Reply #17 on: May 11, 2005, 09:58:16 am »
  Hmm.  I went a little different route.   Check it out and let me know what you think.
-sab
jer2665
  • Last login:January 06, 2006, 04:43:34 pm
    • Jeremy Halvorsen . com
