Author Topic: Space Ace DVD-ROM and Daphne  (Read 4059 times)
psychlone78
  • Last login:October 23, 2005, 11:03:55 pm
  • Shut up foo!!!
« on: May 04, 2005, 05:40:32 pm »
Ok Dahpne experts,
I think I am really close to getting this to work. I used DVD2DAPH to convert space ace roms for daphne. I have those in the SADVD folder in daphne. I got the roms from d-l-p.com. I then pointed to the ace_dvdrom.txt framefile using the daphneloader configure menu. I am still getting this message:
--DAPHNE version 0.99.6
--Command line is: C:\daphne\daphne.exe sae vldp -framefile C:\daphne\framefile\ace_dvdrom.txt -fullscreen
--CPU : GenuineIntel 2200 MHz || Mem : 256 megs
--OS : Windows XP/.NET || Video : Intel(R) 82845G/GL/GE/PE/GV Graphics Controller
LDV1000 : Instantaneous seeking enabled!
Set 640x480 at 32 bpp with flags: 80000001
Initializing sound system ...
No joysticks detected
Loading roms/sae/sae10_u1.bin ... 8192 bytes read into memory
Loading roms/sae/sae10_u2.bin ... 8192 bytes read into memory
Loading roms/sae/sae10_u3.bin ... 8192 bytes read into memory
Loading roms/sae/sae10_u4.bin ... 8192 bytes read into memory
Loading roms/sae/sae10_u5.bin ... 8192 bytes read into memory
Could not open file : C:\daphne\framefile\.\sadvdrom\sa-slates.m2v
Could not initialize laserdisc player!
Shutting down sound system...
Shutting down video display...
Anyone know what I can do next?
DreamWeb
  • Last login:July 25, 2020, 08:36:59 pm
Re: Space Ace DVD-ROM and Daphne
« Reply #1 on: May 04, 2005, 05:46:20 pm »
Looks to me like your framefile has the link to your M2V files incorrect.  Check it and try again.
d.
psychlone78
  • Shut up foo!!!
« Reply #2 on: May 04, 2005, 07:02:52 pm »
Thanks alot Dreamweb. After nearly a month I got it going. Unfortunatley now I got 2 new issues. When I play theres is a weird chime sound when I prees a button, and when I lose and it starts on a new turn, the scene jumps around. It will play as if I am making correct moves then act completely chaotic. What could this be?
daveg2000
  • Last login:January 02, 2009, 08:55:51 pm
  • PSP? Yeah right. GP2X Baby! This thing is awesome
    • www.davegrams.com
« Reply #3 on: May 04, 2005, 10:51:15 pm »
I had an issue on my PC (and this only happened when I used
Svideo out for some reason)
that when a screen ended (in DL) and it did a 'search' for the next
scene... that the sound kinda freaked out and repeated it self
until the next scene would start (maybe 4 or 5 seconds later)
This probably has nothing to do w/your issue.. but just wanted to
throw it out there 'just in case'
If you go into the Daphne folders, and play the '.wav'
files that should play for 'correct' and 'incorrect' moves, does
the .wav file play correctly?
...so I will ask you... "Deal, or No Deal?"
