Author Topic: frogger cab plans  (Read 3206 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
frogger cab plans
« on: May 03, 2005, 11:06:21 pm »
Hi. I am planning on building a repo frogger cabinet a few months down the road. I'm not sure if it will be a dedicated frogger or a mame setup. I want it to look like a original frogger cab. (Accept with a newer coin door) Does anyone have a link to plans for the original cabinet . Any info would be much appreciated.
Crowquill
  • Last login:November 21, 2024, 09:42:17 am
Re: frogger cab plans
« Reply #1 on: May 04, 2005, 01:20:35 am »
I've not found plans anywhere myself. I'm not sure if it'll help, but my Crazy Kong came in a cabinet that seems to be a copy of the old Sega ones. I don't know how different it is, but the pictures look amazingly close with the exception of the monitor not leaning back. I'd be glad to take measurements of it if it would help.
It's pretty nice as a mame cab since you have front-accessable storage on the bottom. My cabinet's slowly getting cleaned up and changed to a MAME cabinet.
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #2 on: May 04, 2005, 01:38:21 am »
Send a PM or public message to Eyedoc.....he's sittin on a frogger at the moment....
http://forum.arcadecontrols.com/index.php/topic,36162.msg317919.html#msg317919
Rub his ego a bit and he might fix ya up with some measurements...
rlemmon
« Reply #3 on: May 04, 2005, 06:22:32 am »
Crowquill , It would be awesome if you could take some measurements ;D when you get a chance. ( therse no hurry) I compaired your pics with all the frogger cab pics i have and they look identical.
thanks ,ron
spriggy
  • Last login:January 28, 2024, 09:45:27 pm
« Reply #4 on: May 04, 2005, 06:48:09 am »
rlemmon,
If you do aquire dimensions for the Frog, be sure to post them on this thread...
http://forum.arcadecontrols.com/index.php/topic,11347.0.html
If Jakobud's not busy, he may compile them for his website.
For your info.
spriggy
"Once a Knight, always a Knight.   Twice a night.. and your doing alright!!" ::)
Crowquill
« Reply #5 on: May 05, 2005, 12:27:47 am »
Sometime in the next couple of days I'll get the measurements.
Does anyone know if height is measured to the start of the curved edge or the sharp corner that would have been there? I'll look at how it's measured on Jakobud's page.
It can't hurt to have the dimensions of another cab floating around, even if it is a knock-off. The only other thing that might be different is that mine is built with 7/8" laminated particle board. I think the sega cabs use 3/4". It shouldn't matter much for what you need it for though.
I don't know if it will help you get started, but I know the control panel face is 24" x 7" and the marquee is 6" x 24". If you haven't guessed, everything between the sides is 24".
My control panel layout is here:
http://forum.arcadecontrols.com/index.php/topic,35501.0.html
I'm going to have to move the top-corner admin buttons in a bit from this picture, but it all fits fine otherwise.
If anyone wants to measure their Frogger (or Carnival, Fortress, Head On, Deep Scan, Invinco!, Digger, Astro Blaster, Eliminator, or Pulsar), that would still be a great help to the community.
« Last Edit: May 05, 2005, 12:42:41 am by Crowquill »
