Author Topic: Is this cheap RGB scan converter any use?  (Read 1325 times)
JoyMonkey
  • Voodoo Wiki Master . . .
  • Last login:June 16, 2025, 09:16:27 pm
  • Candy is Dandy but Liquor is Quicker
    • JoyMonkey.com
« on: May 03, 2005, 10:15:04 pm »
I picked up one of these Covid EZPix 85 scan converters for $20, but is it any good to me? I can't find any details of exactly what it outputs, all I know is it has seperate R,G,B and Sync BNC connectors for output. There's a few of them on eBay but none give too much details.
Do you think this thing crunches SVGA resolutions to an arcade friendly rate? Or have I acquired more useless junk?
StephenH
Re: Is this cheap RGB scan converter any use?
« Reply #1 on: May 04, 2005, 01:57:17 am »
It appears to have a rate display.  If it outputs 15Khz, it should be OK for arcade use.
b3atmania
  • Last login:November 25, 2005, 09:48:57 am
« Reply #2 on: May 04, 2005, 05:32:10 am »
It's not a scan converter. The only thing it "converts" is HV-ync on the input to C-sync on the output. It also convert SOG-sync on the input to C-sync on the output. It's mostly a debug device to read the scanrate of a video source. This device is from 1994 so I don't expect it to work with very high sync rates.
