Author Topic: Hiding XP - What About the Sounds?  (Read 977 times)
Wulfster
  • Last login:June 06, 2005, 12:08:35 am
« on: May 03, 2005, 01:07:06 pm »
I got rid of 90% of the traces of XP in my cabinet, but I can't figure out what I need to change to get rid of the startup/shutdown sounds.
Mamewah is set as my shell, and if I alt-ctrl-del to run explorer, any settings I make  don't apply when I reboot.  I also updated the registry for .Default user with no change.  Am I missing something obvious?
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re: Hiding XP - What About the Sounds?
« Reply #1 on: May 03, 2005, 01:23:02 pm »
Control Panel/Sounds/No Sound theme.
Wulfster
« Reply #2 on: May 03, 2005, 01:33:03 pm »
Those changes don't work after you set MameWah as the shell.
I did find my problem though.  I changed HKU\.Default\AppEvents\Schemes\Apps\.Default\WindowsLogon
where I should have changed HKU\.Default\AppEvents\Schemes\Apps\.Default\SystemStart
It's working now: Pacman startup on startup and Pacman death on shutdown.
