Author Topic: MameWah as Shell Not Shutting Down on Exit  (Read 2497 times)
Wulfster
  • Last login:June 06, 2005, 12:08:35 am
« on: May 02, 2005, 02:23:05 pm »
I have set Mamewah as my default shell under XP Pro, and everything works fine until I exit Mamewah.  When I do, I see a blank Windows background.  I've changed exit_action to shutdown in mamewah.ini with no difference.  Am I missing something?
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
Re: MameWah as Shell Not Shutting Down on Exit
« Reply #1 on: May 02, 2005, 02:30:21 pm »
Does it work right when you select exit and shutdown from the menu?
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
« Reply #2 on: May 02, 2005, 03:21:34 pm »
Forget the exact reason, but apparently that setting refers to an exit through MAMEWAH's menu, so I suggest just exiting through the menu.  Never saw anything about somebody getting it to shutdown by just hitting escape :(
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
« Reply #3 on: May 02, 2005, 03:30:06 pm »
My ESCAPE key works like that.
I think for it to work, you have to mess with the windows setting for logon, require password, etc.
Art
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
Wulfster
« Reply #4 on: May 02, 2005, 04:02:59 pm »
It works as expected when I exit through the menu, but it doesn't when I use escape.  It's probably a registry setting I'm missing.
jcrouse
    • CPViewer
« Reply #5 on: May 03, 2005, 08:15:01 am »
It should shut down completely and turn off the PC if your set the ctrlr file like so:
EXIT_TO_WINDOWS
EXIT_AND_REBOOT
EXIT_AND_SHUTDOWN   "DIK_ESCAPE"
Also check your mamewah.ini file in the MameWAH folder. There is a shutdown setting in there that tells it WHAT to do when the above command is executed.
John
Wulfster
« Reply #6 on: May 03, 2005, 01:33:49 pm »
Changing the ctlr file did the trick for me.  Thanks!
sc1103
« Reply #7 on: May 03, 2005, 07:25:02 pm »
Heh.  Once again, Jcrouse proves me wrong   :-[
jcrouse
    • CPViewer
« Reply #8 on: May 03, 2005, 07:54:56 pm »
LOL, I didn't try to and am not sure how you were wrong. We're all just trying to help.
Peace,
John
sc1103
« Reply #9 on: May 03, 2005, 08:01:43 pm »
lol im just kidding around, Im glad ur there to correct me cuz i dont feel like having ppl taking my advice all the time.  its cool im just messing around  :P
