Author Topic: I am useless. Had enough.  (Read 1897 times)
Bones
  • [Moderator]
« on: April 30, 2005, 11:32:11 pm »
What is wrong with me?
I hold down a good well paid job, have healthy well behaved kids, I am reasonably well read and consider myself of adequate intelligence..... SO WHY CAN'T I FREAKEN MAKE A FREAKEN CONTROL PANEL BOX?
Sorry for shouting.
About 3 years ago I made this (pic). It's not perfect but it's still standing and it was a big job. OK, I had the help of a mate but I did a LOT. So why is it when some 45 degree angles and different wood is used my moron qualities not only rise to the surface but overtake the rest of my brain.
I have pissed away now $200 on a circular saw, $150 for a decent jigsaw and $130 worth of wood and all I have is landfill.
I suck. I suck big hairy donkeys balls.  >:(
DrewKaree
  • HAH! Nice one!
    • A lifelong project
Re: I am useless. Had enough.
« Reply #1 on: April 30, 2005, 11:37:23 pm »
I think it has something to do with your webbed hands and feet.
If you want, I'll pay the shipping and you can send those worthless saws to me, and I'll find them a good home with lots of land where they can run and frolic and whatnot.
At least you have some pieces you can take a sledgehammer to when you finally get it right.  That prospect alone outta cheer you right up! ;D
markrvp
  • NFL Expert
« Reply #2 on: April 30, 2005, 11:54:36 pm »
You're full of S#!T.
DarkKobold
  • Last login:June 18, 2013, 11:31:23 pm
« Reply #3 on: May 01, 2005, 01:41:38 pm »
Didn't your hands get f-'ed up in an accident BB? Isn't that why you are called Broken Bones? How is that going? I'd be surprised if you could still work with wood, after what happened to you, IIRC.
My games: Tapper, Asteroids, Cocktail-MAME, Tron, ROTJ, Tempest, Star Wars (not working)
My wants: Warlords Cocktail
Tailgunner
« Reply #4 on: May 01, 2005, 03:08:12 pm »
By 45 degree cuts I'm guessing you mean rotating the circular saw on it's base and cutting miters with it. That's quite difficult to do when you've got a lot of experience, let alone for your second project. What specifically is causing your problem? Post some pics of what went wrong, everyone who's gotten good at carpentry did so by screwing up so we've all been there.
markrvp
  • NFL Expert
« Reply #5 on: May 01, 2005, 03:12:12 pm »
Posted by markrvp on behalf of BB.
Tailgunner
« Reply #6 on: May 01, 2005, 03:47:27 pm »
Do you have some form of square?  (Framing square, combination square, ect.) If so clamp it to the piece and use it as a cutting guide. Another suggestion, leave the replacement piece long till you get an accurate miter cut. It'll always be easier to cut an accurate 90, so cut your miter first and then cut the piece to proper length.
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #7 on: May 01, 2005, 05:00:16 pm »
Cutting a new replacement and keeping if longer is a good suggtestion if you're really bent on getting a perfect miter joint.
I'd Try sanding the part in the picture on the bottom a little (where the joint is perfect), sand, check, sand check.....keep doing this until the pieces come better aligned.  This should get is closer.
Wood putty is a captenters best bud. A little smeard in there and sanded, then painted and no one but you will know it wasn't PERFECT!
Other than that, looks pretty sweet. I love your CPO as well as what I saw in the Project Announcement thread.....
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
GameOver
  • That's right. I'm Abe Froman.
  • Last login:February 11, 2013, 06:54:31 pm
  • Got a quarter?
    • Check out my cab!
« Reply #8 on: May 01, 2005, 06:11:22 pm »
Don't give up!
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #9 on: May 01, 2005, 08:34:45 pm »
Man....don't feel bad.  I've had plenty of 45 degree angles cut with a compound miter saw not match up.  Angles are tough.  My take is that you do all the tricks and use all the squares and so on to get it as close as you can.  From there it's sandpaper and wood putty to perfection.
Best Kid iPad Apps
tommy
« Reply #10 on: May 01, 2005, 10:27:02 pm »
I have to agree cut/try to cut your angel first and if you mess up cut that angel off and try again, dont make your final cut till the angel is right. You should have many chances to get it right till you run out of length on that panel.
danny_galaga
  • Last login:Yesterday at 05:14:57 am
    • dans cocktail lounge
« Reply #11 on: May 02, 2005, 12:08:45 am »
plastibond is your friend (",)
Bones
  • [Moderator]
« Reply #12 on: May 02, 2005, 02:45:48 am »
The hands are OK! I broke both wrists, destroyed a handful (pun intended) of bones in my right hand plus broke my right arm. Had enough operations to sort out most of my problems (only 1 more to go!). It took me 12 months to learn how to close and use my right hand again but all said and done, I am doing pretty bloody well.
Using power tools is
DrewKaree
  • HAH! Nice one!
« Reply #13 on: May 02, 2005, 08:08:14 pm »
The hands are OK!
It's the REST of him that's really all effed up....especially the semi-useless lump above the shoulders ;) ;D
I have been left as weak as a kitten and some pain still persists but the good news is I can still wank as fiercely as a schoolboy ogling a bra catalogue and I don
Bones
  • [Moderator]
« Reply #14 on: May 04, 2005, 04:31:46 am »
Drew................ Ummmmm, enough said.  ::)     ;D
Last night I brought this. http://forum.arcadecontrols.com/index.php/topic,35285.msg318943.html#msg318943
I just turned it on (to check it actually worked), and it scared the bejeeezus out of me. I wonder if the store will supply me a credit because it's scary sounding?
Looking forward to giving it a whirl on the weekend and getting these cuts right.
Jabba
  • D-Hutt
« Reply #15 on: May 04, 2005, 08:37:00 am »
Hey Bones, That looks pretty sweet....Post some pictures of the finished product when you're done. I have a regular mitre saw, but not the sliding kind. My saw can only cut a total of 6 inches on a 45 horizontal degree cut. I'd be interested in knowing what you thought of it and how big of a board it can cut...
« Reply #16 on: May 04, 2005, 09:07:42 am »
I feel the same way about soldering.  Useless, can't do it right.
