Author Topic: Daphne and Virtual Joystick Madness!!  (Read 973 times)
DreamWeb
  • Last login:July 25, 2020, 08:36:59 pm
« on: April 30, 2005, 07:23:05 pm »
Is there a way to tell Daphne not to even try to find a joystick?
I have Daphne installed on my cab.. and I am using a virtual joystick (in order to run Virtual Tennis properly).
My problem is that.. if I have the virtual joystick installed, Daphne detects this.. and my configuration somehow gets messed up and the games do not work properly.
If I uninstall the virtual joystick.. everything works just fine.  I suspect also that if I didn't have to remap my daphne keys.. it would work fine. (it used to work fine before I remapped the keys in my cab even with the virtual joystick installed)
Any ideas would be helpful!
--Command line is: c:\daphne\daphne.exe LAIR vldp -framefile c:\daphne\framefile\LAIR.txt -fullscreen
--CPU : AuthenticAMD 1950 MHz || Mem : 512 megs
--OS : Windows XP/.NET || Video : RADEON 8500 SERIES
Set 640x480 at 16 bpp with flags: 80000001
Initializing sound system ...
Joystick #0 was successfully opened
Remapping input ...
Loading roms/lair/dl_a_u1.bin ... 65536 bytes read into memory
YUV overlay is done in software (ie unaccelerated).
