Author Topic: MameWAH with MESS and Coleco  (Read 1559 times)
bunny21022102
  • Last login:May 04, 2005, 04:27:16 pm
« on: April 29, 2005, 06:14:16 pm »
Hello all
   First off I have looked for this and have had no luck finding the answer in the forum. Ok the question I am trying to run Colecovision through MameWAH with MESS, now it work and runs the games ok but I can not get the program to exit with the ESC key. I know you can edit in the GUI to make it work but it only works when you use the GUI to start the games not when you use the command line like MameWAH does. Does any one know the command to put in the ini file to allow the ESC key to work. And if you do know the command can you type it out for me as I should in the ini.
Thanks for the help.
I am using
MameWAH v1.61
   MESS v0.95
My Colecovision.ini is
   ### colecovision.ini (mamewah v1.61) ###
emulator_title                            Colecovision
### List Generation Settings ###
rom_path                                  D:\Clasic Systems Set\Coleco v2.01 Complete
rom_extension                             zip
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       F:\Tools\Emulators\mess095b\mess.exe
commandline_format                        coleco -cart "[rompath]\[name].[romext]"{nodosbox}{nosafelaunch}
alt_commandline_format_1                  [name]
alt_commandline_format_2                  [name]
game_specific_config_path
### Artwork Locations ###
artwork_1_image_path
artwork_2_image_path
artwork_3_image_path
artwork_4_image_path
artwork_5_image_path
artwork_6_image_path
artwork_7_image_path
artwork_8_image_path
artwork_9_image_path
artwork_10_image_path
movie_preview_path
movie_artwork_no                          1
### Screen-Saver Settings ###
enable_music_in_screensaver               0
saver_type                                launch_scr
movie_path                                c:\mamewah\ssmovie
movie_fullscreen                          1
quit_delay                                30
wrapper_executable
wrapper_commandline_format                [name]
scr_file                                  c:\mamewah\ms_pacman.scr
### External Application Settings ###
ipc_file_or_path
app_1_executable                          c:\cpvw\cpvw.exe
app_1_commandline_format                  -b=c:\cpvw\images\colecovision.jpg
app_2_executable                          c:\cpvw\cpvw.exe
app_2_commandline_format                  -b=c:\cpvw\images\mamewah.jpg
app_3_executable
app_3_commandline_format
auto_launch_apps
### Additional Settings ###
music_path                                c:\mamewah\music
lcd_display_file_path
lcd_fe_text
### Settings used by MAMEWAH ###
current_list                              0
bunny21022102
Re: MameWAH with MESS and Coleco
« Reply #1 on: April 29, 2005, 06:50:02 pm »
Ok I just figured out my own answer to the question. Here is the code if some on ells is having the same problem, this will open the game with no info or disclaimers and with no GUI so you can use the ESC key to exit the game. And it only took me 9 hrs to figure it out. :P
emulator_title
jcrouse
    • CPViewer
« Reply #2 on: April 29, 2005, 08:20:40 pm »
I see your a noob. Make sure you check out the INI files on my website at http://home.comcast.net/~cpviewer . The will help you with some of the settings.
John
bunny21022102
« Reply #3 on: April 29, 2005, 08:51:27 pm »
Thanks John
 your site is great that it where I got the files originaly from I just had to add the -skip_disclaimer -skip_gameinfo -nonewui  into the command line.
