Author Topic: entering OK in mame using a joypad?  (Read 1279 times)
vartech
  • Last login:March 20, 2013, 03:38:17 pm
  • The Great Swordsman Hiko
« on: April 29, 2005, 08:12:28 am »
I have a GP-Wiz which I have configured in mamewah and mame to accept as a gamepad.  how do I program mame to accept left right on the joypad as ok? for games that require you to hit OK
Tiger-Heli
    • Tiger-Heli
Re: entering OK in mame using a joypad?
« Reply #1 on: April 29, 2005, 08:30:58 am »
Actually, it should work fine without doing anything.  If it doesn't:
Well - the simplest way is to go into the tab menu in MAME and look (probably under Inputs -all games - User Interface) - For UI LEFT - and press the joysticks left so it probably says J1Left and UI RIGHT and press the joystick RIGHT so it probably says J1Right.
Then it will work.
The better way is to go into your MAME.ini file and set
-skip disclaimer
-skip gameinfo
-skip warnings
-skip baddumps
on, but you might need buddaMAME or NoNAMEMAME to have all the options,
Or see this page or SirPoonga has some hacks on his page to do this as well.
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #2 on: April 29, 2005, 11:28:08 am »
Cool tips, thanks! And here I was wondering if I was going to have to map an admin button to OK. :)
