Author Topic: KeytoJoy?  (Read 26385 times)
jelwell
  • Last login:December 24, 2014, 03:47:21 pm
KeytoJoy?
« on: April 27, 2005, 07:17:12 pm »
I've heard of JoyToKey. Is there something that goes the other way?
I want a KeyToJoy. Something that will emulate a Joystick via a keyboard.
The problem is that I have a PC game that the keyboard controls are not customizable that I want to put on my cabinet. However, the keyboard controls for this game are not changeable. The game was designed to play using a joystick/gamepad.
I might be able to get away with loading a different IPAC setting just for this game, but I'd like to explore the possibility of simply mapping my keyboard to a Virtual Gamepad.
Any ideas?
Joseph Elwell.
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
Re: KeytoJoy?
« Reply #1 on: April 27, 2005, 07:50:07 pm »
Theres one called RBJoy that I believe works as you want it to - unfortunately the page is in German. Good luck! http://www.rbsoft.de/
jelwell
Re: KeytoJoy?
« Reply #2 on: April 27, 2005, 08:23:07 pm »
This appears to have the same functionality as KeyToJoy. That is, it lets you use a joystick/gamecontroller instead of a keyboard. I want to go the other way.
Maybe the english translation is off. I will download and try it at home.
Joseph Elwell.
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
Re: KeytoJoy?
« Reply #3 on: April 28, 2005, 12:45:04 am »
There is such a program floating around out there.  If you run a search on this board for "Virtua Tennis" you'll find the info you need.
-Ace-
I want my own arcade controls!
chemame
  • Last login:January 26, 2007, 01:54:05 pm
Re: KeytoJoy?
« Reply #4 on: April 28, 2005, 09:48:54 am »
I didn't see if the solution was what lilwolf was looking for, but I think this thread was the same question, and I think it was answered: http://forum.arcadecontrols.com/index.php/topic,34259.0.html
Tiger-Heli
    • Tiger-Heli
Re: KeytoJoy?
« Reply #5 on: April 28, 2005, 10:33:08 am »
Yep, you actually want the thread linked at the end of the one above: http://forum.arcadecontrols.com/index.php/topic,10778.msg86775.html#msg86775
jelwell
Re: KeytoJoy?
« Reply #6 on: April 28, 2005, 12:54:49 pm »
Thanks everyone!
I was searching all over for days looking for this. The only reason I didn't give up was because I could have sworn that I've seen this before.
Joseph Elwell.
