Author Topic: Can you use plexiglass for a bezel?  (Read 5513 times)
2PacMan
  • Last login:November 06, 2009, 08:33:45 am
  • PacMan collection
« on: April 27, 2005, 09:21:34 am »
I'm building my own arcade machine, and i need a bezel.  Rather than going with glass which is expensive, can i use plexiglass, or will it distort the picture....would any other material work?
rchadd
  • Last login:June 10, 2013, 06:14:06 am
  • Made in Cornwall
Re: Can you use plexiglass for a bezel?
« Reply #1 on: April 27, 2005, 09:52:51 am »
yes - but i think glass is better finish as it does not scratch as easilly
tommy
« Reply #2 on: April 27, 2005, 09:59:46 am »
Glass!
2PacMan
  • PacMan collection
« Reply #3 on: April 27, 2005, 10:03:50 am »
Well, i understand that glass would be the best way to go, but it's expensive!  It's going to be adults playing my game, so i don't think i'll have to worry about scratching too much, no one will be very rough with it.  I just want to make sure it won't distort the picture...sometimes i've seen it give off a rainbow tinge to the light.
How much did it cost for your glass including cutting...i need about a 24x24 inch square.
Stingray
« Reply #4 on: April 27, 2005, 10:13:29 am »
I used plexiglass. The picture looks fine through it. I've never noticed any distortion.
-S
tommy
« Reply #5 on: April 27, 2005, 10:22:11 am »
If your going to use plexi dont leave you cab near any windows, the plastic will get cloudy over time from the sun , ive seen it time and time again installing plexi in windows for houses. Where i come from i charge more for plexi then the same size in glass, glass is a better choice and at some point your going to have to replace the plexi, the glass not really.
Veinman
  • Last login:June 11, 2014, 02:40:27 pm
  • "Done" with The Legend of Mame
    • The Gelatinous Cube
« Reply #6 on: April 27, 2005, 11:00:11 am »
Wouldn't Lexan be the best of both worlds?
Stingray
« Reply #7 on: April 27, 2005, 11:42:40 am »
Good advice. Arcade machines are supposed to be in dimly lit environments anyway. My wife calls my game room "the cave" because it's always so dark in there. :)
-S
2PacMan
  • PacMan collection
« Reply #8 on: April 27, 2005, 12:45:15 pm »
Thanks for the input guys...i just called Lowe's and actually, it's cheaper to buy glass than the plexi....i had no idea, i thought plexi would be way cheaper.  So i'm going with glass.  Thanks again guys.
Chris
    • Chris's MAME Cabinet
« Reply #9 on: May 23, 2005, 11:01:02 am »
Make sure you're getting tempered glass!
--Chris
Stingray
« Reply #10 on: May 23, 2005, 11:13:22 am »
Lowes, Home Depot & the like will gouge you on plexi. You can get it way, way cheaper from a plastics specialty shop.
-S
Dire Radiant
  • Last login:January 23, 2025, 06:30:10 pm
  • Cor, chief!
« Reply #11 on: May 23, 2005, 01:42:00 pm »
No kidding. Plexi from Home Depot in the size I want for mine would cost me about $35. The local glass place quoted me $27 for tempered.
omar
  • Last login:October 08, 2009, 05:40:43 pm
« Reply #12 on: May 23, 2005, 03:19:06 pm »
Actually I bought a 36x28 piece of acrylic from Home Depot for $13.00. I don't notice any ditstortion at all. The only downside is that it's easy to scratch. But cutting it is a breeze.
MonitorGuru
« Reply #13 on: May 23, 2005, 05:11:51 pm »
Considering you can get a 22" x 32" piece of 1/4" thick glass for the top of a Midway cocktail table, including 4 radius cuts, frosted rounded edges AND tempering for about $45 in most cities, a 24x24 piece of tempered 3/16" glass for an upright bezel without rounded edges or corner radius cuts, should cost only about $25... much less than a similar piece of Lexan.. and a LOT less scratchable.
