Author Topic: WG9200 flicker  (Read 1431 times)
Buschmaster
  • Last login:January 21, 2007, 06:57:09 pm
  • Trying to finish my first cabinet. Almost there!
WG9200 flicker
« on: April 26, 2005, 09:18:45 am »
I get a line that scrolls from the bottom to the top on my monitor.  I'm guessing there is an adjustment for this on the front left of the monitor am I correct in assuming this?  Just don't want to mess with it till I know for sure.
It's the Wells Gardner 9200 42a model.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: WG9200 flicker
« Reply #1 on: April 26, 2005, 03:04:24 pm »
Make sure you have a good ground.
Later,
dabone
Buschmaster
Re: WG9200 flicker
« Reply #2 on: April 28, 2005, 08:21:37 am »
Talked with WG and they said the same thing that it may be the ground.  (Had an unrelated call into them)
Since there won't be any true current going through it I'm going to ground it out on the screw of an electrical outlet box.  Simple speaker wire will be enough.
I'd originally thought the ground from the power would cord would have taken care of that, but guess not.
