Author Topic: ePSXe and Mamewah  (Read 2556 times)
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
ePSXe and Mamewah
« on: April 26, 2005, 08:48:55 am »
hello,
I configure ePSXe with Mamewah1.61.Once i found games in the list but failed to run any one of them.
Is there any one who is running ePSXe with Mamewah successfully.
any help.
thanks in advance.
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
Re: ePSXe and Mamewah
« Reply #1 on: April 26, 2005, 07:39:20 pm »
Did you use Screaming's Mamewah config? That does most of it, then you just gotta point out your directories, and have it create the game list.  If you still have issues, I believe you can only use a .ISO format, no Bin/Cue, Blindwrite, Alcohol's MDF/MDS, .nrg, etc. so make sure theyre in the correct format.  Also, if you manually configured I'd suggest googling it b/c someone wrote the manula settings out somewheres.
jcrouse
    • CPViewer
« Reply #2 on: April 26, 2005, 10:08:29 pm »
Many of us have it working. First make sure it works outside of MameWAH. BIN/Cue file DO work and work WELL. I have about 420 of them and they all work great. You may want to make a trip to my website. There is a commandline wrapper there for ePSXe. It requires the Microsoft .Net framework and works with BIN/cue files. It also requires Daemon Tools. It will automatically mount an image in Daemon Tools, Start ePSXe, Start the Game, Exit with the ESC key and unmount the image. You can find it on the downloads page at http://home.comcast.net/~cpviewer
Enjoy,
John
ahmer
  • Do as you like.
« Reply #3 on: April 27, 2005, 07:58:19 am »
Yeah i am using Alcohol's Clone CD Images *.IMG extentions.
They are working fine,when i load any IMG file an ISO in ePEXe.No prob
there.
I don't know how to make them in *.BIN or *.CUE format.
please tell me.
well i just get Screaming's Mamewah config.
lets see what happen :)
sc1103
« Reply #4 on: April 27, 2005, 05:05:18 pm »
I meant for Screaming's config-that does not handle bin/cue format I think.  Otherwise you are correct  :angel:
ahmer
  • Do as you like.
« Reply #5 on: April 28, 2005, 12:29:47 pm »
MameWah Screming's config did not start  :(
it gives an error .(MSSOREE.DLL) not found,while i am using win98.
am i missing some thing?
need help..
sc1103
« Reply #6 on: April 28, 2005, 03:19:51 pm »
You need the newest .NET Framework...that might be it not real sure though try PMing him
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
« Reply #7 on: April 28, 2005, 03:34:19 pm »
Yep, this usuallly means the .NET Framework isn't installed.  Install the .NET Framework and then try again.
-sab
ahmer
  • Do as you like.
« Reply #8 on: April 29, 2005, 08:47:21 am »
-sab
Oh yes.
I just forgot to get the .NET FRAMWORK
screaming
  • Registered lUser
« Reply #9 on: April 29, 2005, 09:45:49 am »
ahmer
  • Do as you like.
« Reply #10 on: May 01, 2005, 08:00:35 am »
hey Screaming,I installed .NET FRAMWORK 1.1 then when i run Mamewah Config i found an error messege.
screaming
  • Registered lUser
« Reply #11 on: May 01, 2005, 09:50:26 am »
  Hm.  I'll see which version of the .NET Framework I have installed when I get home tonight.
  Are you sure you installed version 1.1?  You might want to run Windows Update and get all your .NET updates through there to be sure.
-sab
ahmer
  • Do as you like.
« Reply #12 on: May 01, 2005, 07:14:40 pm »
-sab
I followed the link and download .NET FRAMWORK 1.1 :-\
Quote from: screaming
-sab
I think there is no more update for win98 except Internet Explorer .
BTW ,I am currently using an updated Internet explorer 6.0 SP1.
Tonight i just Installed XP,I will check for it.
« Last Edit: May 01, 2005, 07:25:41 pm by ahmer »
ahmer
  • Do as you like.
« Reply #13 on: May 03, 2005, 06:29:43 pm »
Finally i install XP and mamewah config run on it.
Screaming,your Mamewah config did not help me to set epsxe under Mamewah.
Do i need any other utility?Daemon tools i think.
it will be pleasure if any one can send me some INI FILES.
thanks.
jcrouse
    • CPViewer
« Reply #14 on: May 03, 2005, 06:59:42 pm »
What format are your games in, ISO/MP3 or Bin/cue. As I stated above, Bin/cues work great for many of us. If your's are in that format it should be a matter of looking at the INI file on my website. Did you not see my earlier post. It tells you where to get exactly what your asking for. Am I missing something here?
### List Generation Settings ###
rom_path                                  d:\epsxe\roms
rom_extension                             bin
dat_file
nms_file
catver_ini_file
list_generation_method                    rom_folder
### Execution Settings ###
emulator_executable                       c:\epsxe\epsxe.exe
commandline_format                        -nogui -loadbin "[rompath]\[name].[romext]"{dosbox}{safelaunch}
alt_commandline_format_1                  [name]
alt_commandline_format_2                  [name]
game_specific_config_path
Enjoy,
John
ahmer
  • Do as you like.
« Reply #15 on: May 03, 2005, 07:14:32 pm »
Thanks jcrouse,
I am using IMG format.As i know IMG format are supported in ePSXe ISO loading formats and also working fine with epsxe.
I don't know which Image Burning utiliy makes BIN/CUE formats.
l
 let me check for it.
jcrouse
    • CPViewer
« Reply #16 on: May 03, 2005, 07:20:09 pm »
Alcohol 120% will make/read/mount bin/cue format.
John
ahmer
  • Do as you like.
« Reply #17 on: May 03, 2005, 07:48:58 pm »
Great Jcrouse,
finally mamewah works with epsxe .
Btw, IMG Formats Extensions are also working with mamewah.
Now i am looking at your site some Layouts for it.  :)
thanks for help.
