Author Topic: Need help removing knob from joystick..  (Read 1694 times)
hitandrun
  • Last login:August 03, 2010, 10:13:08 pm
« on: April 25, 2005, 04:06:05 pm »
Does anyone know for sure how to get the knob off of this joystick?
NY_in_TX
  • Last login:February 25, 2017, 11:19:54 am
  • First play's free...next one will cost ya
Re: Need help removing knob from joystick..
« Reply #1 on: April 25, 2005, 04:10:05 pm »
pull off the eclip from the bottom of the stick!!
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: April 25, 2005, 10:04:15 pm »
Oh man, I see you've chewed up the shaft there. Get a small flathead screwdriver. Push DOWN on that black plastic that's around the shaft. All will be obvious once you do that. Just insrt the screwdriver into a gap in the E-clip and then twist till you pop the clip off.
NO MORE!!
RandyT
    • GroovyGameGear.com
« Reply #3 on: April 25, 2005, 10:12:55 pm »
If there are a lot of burrs kicked up on that shaft, it might be fun to get that out of there now.
You might need file that down a little if it still won't pull through after removing the e-clip.
RandyT
hitandrun
« Reply #4 on: April 26, 2005, 01:10:52 am »
Thanks for the help!!  ;D  Actually the shaft was just fine.  The camera made it look bad.  Once the E clip was out, it was smooth as silk.  This control panel has seen better days though.
« Reply #5 on: April 26, 2005, 09:29:23 am »
My word, he circumsized it.
