Author Topic: Quickly need ipacs/hagstrom command line config  (Read 3396 times)
Lilwolf
« on: May 07, 2002, 11:02:43 pm »
Whats the command line to configure a ipac?  (I have a MK, and need to make sure that a change to my frontend will work with it).
How about hagstroms?
MK's example
keymap cp4
where cp4 is a file in that directory with the keymapping in it.
thanks
ErikRuud
  • Last login:March 05, 2021, 10:20:27 am
Re: Quickly need ipacs/hagstrom command line confi
« Reply #1 on: May 08, 2002, 07:23:13 am »
ipacutil myconfig.cfg /b /s
The /b tells the utility to batch load the config file without going into the programming screen.  The /s is for silent mode which suppresses the dos message output.
There are two more options that some people need to avoid timeout errors while sending the config to the IPac.  I think they are /d and /t, but I don't have the documentation with me.
American Laser Games Wrapper
O2em Rom Utility
towlebooth
  • Last login:October 10, 2011, 06:18:58 pm
  • Cab in progress
« Reply #2 on: May 08, 2002, 01:31:24 pm »
For the Hagstrom KE72 & KE72T:
KE72LOAD [config filename] 1
The one signifies what COM port you are using.  There are other ways to connect, but I can't remember them (at work right now).
This assumes that you have their KE72LOAD program on the PC.
Chad
