Author Topic: Anyone able to use the Adv CD options  (Read 1450 times)
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« on: April 24, 2005, 01:35:08 pm »
Has anyone ever got the advaceCD option Makepart to boot after it has formatted the HD and copied the files over?
I did everything by the book and no go.. says im missing files...
Sounds like the advanceCd .bat file is missing something and or there is a file missing from the distro to make it work.
thx
 -d88
« Last Edit: April 27, 2005, 11:19:07 am by delta88 »
Captain_Dingo
  • Last login:November 28, 2018, 05:57:32 pm
Re: advance menu,mame,cd..name it.. all a pain...
« Reply #1 on: April 24, 2005, 01:52:27 pm »
Check out Easy MAMECab...
It's rough finding good information about the Advance stuff on the web, but I know some good stuff is on that site.
delta88
« Reply #2 on: April 24, 2005, 02:04:25 pm »
Almost but no, that is all about advanceMmae and menu. I am trying to get the advanceCd partion to a HD to boot. but it Says that I am missing files which leads me to beleive that the distro is missing them cause I did it all by the book with no luck.
The error I get when I try to boot is:
InitDiskBad or missing command Interpreter: command.com /P /E:256
Enter the full shell command line:
« Last Edit: April 24, 2005, 02:11:39 pm by delta88 »
delta88
« Reply #3 on: April 26, 2005, 07:56:36 pm »
Anyone ever see this? use it? It sounds really cool if its able to work. I tried the source forge forums for the app but its deserted.
delta88
Re: Anyone able to use the Adv CD options
« Reply #4 on: April 27, 2005, 11:19:48 am »
Anyone? Ever? This forgien?
delta88
« Reply #5 on: April 28, 2005, 08:48:59 pm »
maybe sorta kinda?
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« Reply #6 on: April 29, 2005, 08:42:00 am »
I don't know but more about ADV CD but once  you run bat file for Formating  1 Harddisk partion to  copy Adv stuff in it.
I think ADV CD format that partition and make it a Linux Partion so you can not see it windows.
delta88
« Reply #7 on: April 29, 2005, 11:30:29 am »
..?.... What was that?...  I made all the motions and get an error. trying to find out what it means. or if this is still an option in testing.
