Author Topic: problem launching mame from mamewah with a batch file  (Read 1065 times)
vibez
  • Last login:February 09, 2011, 08:33:20 am
« on: April 23, 2005, 02:25:23 pm »
If I launch mame from mamewah dirctly (pointing to mame.exe) It reads the mame.ini & applies the settings just fine for the custom resolutions I have set up. But If use this batch, it ignores the custom resolutions settings. This batch should cause mame to read the config as before.
c:\mame\mame.exe d:\roms\%1 -rc
I cant understand what is wrong
EDIT::
please delete.
I had to change the bat to do this
Cd \
cd mame
mame.exe d:\roms\%1
apparently it doesnt pick up the switches if you run mame with a path infront of it
« Last Edit: April 23, 2005, 02:37:26 pm by vibez »
screaming
  • Sweet! I'mma go make me some popovers!
  • Last login:August 14, 2019, 03:15:34 pm
  • Registered lUser
    • shift eight (*) generation
Re: problem launching mame from mamewah with a batch file
« Reply #1 on: April 23, 2005, 03:50:38 pm »
It picks up the switches, but it can't find the configuration files in the directory you're running "c:\mame\mame.exe" from.  That's why it works when you "cd mame" first.
-sab
vibez
« Reply #2 on: April 23, 2005, 04:04:54 pm »
thanks I wondered why it did that.
