Author Topic: CRT tester help!  (Read 5752 times)
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
CRT tester help!
« on: April 20, 2005, 11:30:15 pm »
Does anyone out there have a CR-XA universal adapter for a BK Precision CRT tester? I'm trying to build a CR-31 and CR-23 adapter for my BK 470 tester, but I can't for the life of me figure out which wires go where. If someone has a CR-XA could you please map the wire colours and locations in the connector for me so I can cross reference to my adapter chart to make my adapters correctly?
Thanks a bunch!
www.wolfelectronics.ca
Cap Kits for Canadians!
menace
Re: CRT tester help!
« Reply #1 on: April 21, 2005, 07:22:20 am »
Is this what you are looking for?
menace
« Reply #2 on: April 21, 2005, 07:23:39 am »
I'm curious to see how the 470 fares in one of these ad-hoc DIY adapters--please post back with your results....
Ken Layton
  • Guru
  • Technician
« Reply #3 on: April 21, 2005, 11:14:35 am »
Dandy Manufacturing makes a far superior "universal" adapter for B&K testers. It's called the "Dandy Dapter" and it's been available for years.
Dandy Manufacturing Company
Dan Randall TV Service
2323 Gibson St.
Muskogee, Oklahoma 74403
Phone: 1-800-331-9658 or (918) 682-4286
Their unit comes with several universal sockets and it does projection tv tubes, too. It comes with a tube setup/cross reference chart also.
« Last Edit: April 21, 2005, 11:33:00 am by Ken Layton »
Grauwulf
  • Button Masher
« Reply #4 on: April 21, 2005, 11:41:41 pm »
Menace> Thanks, but I have that information from the setup book already. What that doesn't tell me is what wires go where in the connector.
Ken> I really don't want to buy an adapter, I have all the componenets to make my own, I just need to know how to wire everything. I tried to map the wires from one of my other adapters, but I didn't have much luck.
menace
« Reply #5 on: April 22, 2005, 07:32:08 am »
ok--if I'm understanding you right you have the 470 pinout (i.e. what color wire has what function) but not the cr-23 pinout?
here's my thread:
http://forum.arcadecontrols.com/index.php?topic=35351.0
inside is the cr-23 pinout, the corresponding function of each pin on the crt and a link to the B&K manual showing what each wire on the 467/470 does--so between the two you can corss reference and make up the adapter.
Ken Layton
  • Guru
  • Technician
« Reply #6 on: April 22, 2005, 11:43:25 am »
For everyone's information, this is taken directly from the "FAQ" on bkprecision.com
"Do you still supply CRT adapters for your older rejuvenators?
Yes, B&K Precision's Parts and Documentation department sells 'CR' adapters and Set-up Charts for models 467 through the 490B".
So the oldest unit they provide adapters for is the 467 (30 years old). The 467 is still a great unit and I use mine all the time.
Grauwulf
  • Button Masher
« Reply #7 on: April 22, 2005, 11:46:25 pm »
I know what each wire on the CR-23 is supposed to do, what I do not know is what the pinout on the connector on the tester is. The 470 does not have the same connector for the adapters as the 466 does.
Ken Layton
  • Guru
  • Technician
« Reply #8 on: April 23, 2005, 12:44:51 am »
According to the 466 to 467/490 conversion instructions this is the pinout on the tester side of the cable for the 467/470/480/490:
1 Heater
2 Heater
3 G1 red
4 G1 green
5 G1 blue
6 K red
7 K green
8 K blue
9 G2 red
10 G2 green
11 G2 blue
12 G3, G4 (focus)
Connector is Molex # 03-06-2122
Pins are Molex # 02-06-2132
