Author Topic: how to put together happ competition-stick  (Read 1171 times)
Felice
  • Last login:November 05, 2007, 11:53:26 am
« on: April 15, 2005, 08:14:18 pm »
I bought a happ-competion-stick but there is no way I can build the parts to one functioning stick.
The problem is that the white shaft (it's called 95-0199-10 on the design of
« Last Edit: April 15, 2005, 08:34:19 pm by Felice »
TOK
  • Last login:January 24, 2024, 05:14:24 pm
  • The Game Always Wins
Re: how to put together happ competition-stick
« Reply #1 on: April 15, 2005, 08:55:20 pm »
It's held under tension. Put it together the way the instructions show then push down on the top of the stick. There is enough "spring" in the handle to fit the E clip over if you push down on the top.
Felice
« Reply #2 on: April 15, 2005, 09:22:51 pm »
Thx man; I could do it now.
I have to mention that the square plastic at the bottem which pushes the microswithes it not stable. I mean it turns around a little while using the stick, so the degrees when hitting the diagonals does change while using the stick which can't be the purpose I think. Do I something wrong? (BTW I didn' t put it in my arcade-unit yet).
Vicious
« Reply #3 on: April 15, 2005, 09:25:52 pm »
That plastic square does move a little, but it doesn't affect gameplay.  You put it together correctly.
