Author Topic: Hacking Power On Switch for Dell  (Read 2007 times)
sc1103
  • Last login:December 11, 2020, 08:37:35 pm
« on: April 14, 2005, 06:36:21 pm »
I know that the Dell Systems use a proprietary connector to power on...anybody have one hacked to an arcade power on switch they'd consider selling? Id do it myself but I dont trust myself w/ somethin like that
« Last Edit: April 15, 2005, 07:43:43 pm by sc1103 »
SirPeale
  • Green Mountain Man
Re: WTB: Hacked Power On Switch for Dell
« Reply #1 on: April 14, 2005, 07:08:55 pm »
You're saying you can't connect two wires together?
sc1103
« Reply #2 on: April 14, 2005, 09:01:54 pm »
Wow...I'm stupid then...sorry the only thread I saw got over my head...but thats probably because I was half asleep or somethin...I'll have to take a look at this then.  SOrry about that  ;D
cholin
  • Last login:July 16, 2009, 09:22:25 pm
    • Nilok Productions
« Reply #3 on: April 14, 2005, 10:26:00 pm »
Many people here will be *more than happy* to sell you two wires attached together ;D
Goz
  • KOTA
« Reply #4 on: April 14, 2005, 11:01:43 pm »
The green and any black wire touching should turn the power supply on.
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #5 on: April 14, 2005, 11:35:57 pm »
I think the issue he is wrestling with is a function of Dell having a proprietary molex connector on the motherboard that is not clearly documented so determining which two pins actually lead to the power switch is not as striaghtforward as normal motherboards.
Which model Dell do you have?
sc1103
« Reply #6 on: April 15, 2005, 05:03:58 pm »
Ehh...it's a dell dimension xps T650r
Intel Pentium 3 648 mHz
Moderators feel free to move this to another Board, as it is not pertinent to a B/S/T board
Dougmeister
  • Last login:July 27, 2018, 05:44:52 pm
  • Dig-Doug
Re: Hacking Power On Switch for Dell
« Reply #7 on: April 19, 2005, 06:47:22 am »
I'm in the same boat.  I have a Dimension P3-733.  The molex has eight sets of pins that go to the MB.  I can trace four (4) back to the power-on switch.
I thought about soldering wires to the backside of the printed circuit board that holds the existing switch, bu my soldering skills aren't that great.
Then I read about splicing the wires, but I'd have to strip them first, and they're all kinda small and bound together in that stupid ribbon cable...
Then I read about randomly shorting out the pins on the MB to see which ones turn on the computer.  It seems like that could hurt something, though?  Anyway, if you found those, THEN what would you do?  Jam extra wires up inside the existing molex and force it on?
cholin
    • Nilok Productions
« Reply #8 on: April 19, 2005, 07:43:03 am »
Shorting out the pins wont hurt anything, because its just connecting two wires, like a pushbutton does.  What do you think happens when you press the ON button?  Answer:  It shorts those two pins.
Keller888
  • Last login:September 26, 2007, 09:31:43 pm
  • I love the smell of solder in the morning!
« Reply #9 on: April 19, 2005, 10:33:54 am »
I just got finished doing this exact same thing last night.  I have a Dell XPS 450, and i wanted to extend the power switch up to my control panel.  I simply soldered two wires under the Dell switch, and ran them to a button under my control panel.  It works perfect.
Dougmeister
  • Dig-Doug
« Reply #10 on: April 19, 2005, 10:50:10 am »
