Author Topic: Startup screen idea...  (Read 1709 times)
cdbrown
  • Bowowow
« on: November 20, 2002, 04:05:09 am »
This may already be something that the frontends are capable of but I only just thought of it.  So here goes...
Are there any frontends that have a startup screen like a normal game where it shows a messed up screen then goes through and checks the various chips on the boards.  The same you see when you start up a game.
Would be nice to have this type of start up when first powering on the machine especially if you see this instead of the windows startup - make it slightly more authentic  ???
Dunno - just an idea.
-cdbrown
bhille
  • Last login:January 02, 2003, 11:39:40 pm
  • Be the ball...err...be the arcade machine...
Re:Startup screen idea...
« Reply #1 on: November 21, 2002, 12:07:26 am »
I think it's an awesome idea....just wish I knew how to do that!
Brian
Brad Lee
  • Last login:May 26, 2005, 11:39:04 am
    • 666
« Reply #2 on: November 21, 2002, 09:28:26 am »
I know with windows 95/98 that changing the picture is as easy as creating a new logo.sys file(actually a .bmp), and that you are able to animate these fairly easily
I haven't doen this in a while, but heres what I recall
Resize to 320x480, windows will stretch it when its used
Rename to logo.sys, and copy it to c:\
Now to animate it, uses either the first 16 colors in the palette or the last 16(sorry, can't remember), and it cycles through them
Say I made color 0 black, then color 1 a little lighter, and 2 even lighter, until I get to white as color 15, and then 16-255 could be whatever static colors I wanted. Now If I made my image all color 0, I'd have a solid black .bmp. When I loaded windows though, it would start as solid black, then any pixels that are color 0 would cycle through the 16 available colors- basically it would fade to white, and then go black and start over
Not true animation, but it could be used for flashing test(colors 0-7 black, 8-15 white) or a Williams style screen
To be sure, check google for something like "windows 98 startup logo.sys animation"
win2000 I have never messed with but I think it's similar, and XP I know there are prog's out there that can change the startup screens and sequences
Brad Lee
    • 666
« Reply #3 on: November 21, 2002, 09:32:25 am »
http://www.nucleus.com/~kmcmurdo/win95logo.html
For 2000 & XP you need to use reshack.exe or a similar program to change the images
